I have an 08 FX Nytro (standard) with the 121"x15"x1.75" Backcountry track and Slydog Powerhounds installed. All preloads are set to factory settings. Front clickers are set to 3/4's hard (rebound and compression). Front limiter strap is set to the middle and back limiter strap is set at the top hole. Sway bar is attached.
I ride some trail and some deep powder and I realize normally when you set up this sled to ride well in one conditions you are sacrificing a good ride in the other conditions. It currently rides great for me in the deep powder, but the ride on trails isn't as great. I get some inside ski lift and even tho it eats up the bumps, it's a harsh ride.
What can I change to get a more comfortable ride on rough trail?
What can I change to reduce inner ski lift?
And if I make your recommended changes, how will it sacrifice my deep powder ride?
Thanks,
Will
