trosell14843
- Nov 17, 2014
- 2005 vector
I can't believe with 588 Miles I am already having rust on the a arms. Just life? I guess doing the powder coat has to be.
nydiver
- Apr 30, 2015
- Syracuse, NY
- 09 Nytro XTX
09 Nytro RTX
91 Phazer II (gotta have a classic / kids bomber :) )
Open trailer? I see stone in the pic too, like its stored over a stone "pad". Ideally you'd like a nice attached garage cement floor, then it goes down to a barn or storage cement floor, wood shed floor, a cement pad with a portable garage, cement pad no cover, stone pad, straight up dirt. Wash the sled, and wash it often, spray it down before storage with a protectant, like armor-all or a spray detailer, this will coat the surface in ions to repel moisture thereby slowing rusting and corrosion.
Clean off the rust stains with vinegar and try and mitigate the damage from returning. Powder coating will only buy you some time and cost you money, you have to attack the source to really end your issue.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Probably because those are areas that get less paint to protect the bare metal. You could try to clean it up and touch it up with a brush applied paint but would likely return. I had mine powder coated and have held up great. The powder is applied using static so it goes everywhere and then baked.
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
So just to be clear, this is on an Apex that was built in Japan?
This is for all the whiners in the Viper forum who "Want a True Built in Japan snowmobile", because they are perfect and the Arctic Crap/Yamaha partnership is terrible and every issue on a brand new sled is attributed to the poor quality coming from Thief River. It is said with tongue and cheek.
snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
A little rust Sure is better than not starting or blown starter or the many other problems the kitty has had just my 2 cents.
The top a arm is aluminum on my attak.
stevieu1
I sandblasted mine and painted them with spray on bedliner. Looks good and very durable. Easy to touch up every year too.
Only did the bottom, the top ones weren't rusted.
trosell14843
- Nov 17, 2014
- 2005 vector
I liked the black bedliner!!
InRBigness
- Apr 10, 2014
I quite agree. My point was that nothing is perfect all the time. I will venture to say that even this model had issues when it was first introduced and they worked to fix it. That is how the development cycle works.
trosell14843
- Nov 17, 2014
- 2005 vector
Could you not just spray over the paint with the bedliner
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Usually, bedliner is sprayed over paint. Just the rust that has to be removed.
trosell14843
- Nov 17, 2014
- 2005 vector
Cool that's my plan then
