WinterWolf
- Mar 25, 2017
- Connecticut
Numbers are on the helix(0,3,6,9) from Dalton too....Add the numbers together x 10%(IE": 3+3=6 X 10%= 60 degrees)
yes 3-3(60 degrees) should be where you want it, especially with the new sec springs we have avail now. Last season we did not have any, so we all tried 70 degrees to try to get more bottom end rpms. New springs will be a world of difference.
You "twist" the helix Clockwise, rolling the ramps onto the rollers....when installing it. These are pretty easy to do without a tool if you dont have one. Unlike the doos which compression rod tool really is needed.
Notice the BLUE markings on stock helix and sheave, these blue marks are the STOCK settings for tangs, 3-3 is shown here.
Here are some pics of tangs and numbers on helix...
Dan
Stock helix with 0,3,6,9 numbered holes for tang
3 numbered holes on sheave for tang, notice the number, left side near rollers(2)
Dalton helix with 0,3,6,9 holes for tangs(same as stock)
Orange TP sec spring, showing tangs on each end
33/35 helix RAMP, showing the slight curve to the naked eye--shallower(33 closer) to steeper(35 further down)
Excellent post Dan...thanks so much!! It now makes perfect sense!! Pictures are great too showing it all!! I do appreciate the time you took to show and explain all this..Thank You!
jimmyhighway
- Feb 6, 2006
- Northwestern Ontario
- 13 Skidoo Freeride 137
11 Yamaha Nypex MCX
Good spot to post Dales new secondary spring.
Anxious to test this one...
View attachment 130262 View attachment 130263
For comparison does anyone have specs on the purple EPI secondary spring? Alot of high hp turbo yamahas have run this spring to prevent slippage in the secondary.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Wow ordered my black orange secondary spring Friday afternoon and it arrived at my door before 8am this morning. Thanks Dalton.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Agree.....I have always had the best experiences with Dale at Dalton.Wow ordered my black orange secondary spring Friday afternoon and it arrived at my door before 8am this morning. Thanks Dalton.
Things get to me fast here in Ontario too. Always surprises me how fast. Got my B/O and 39/35 helix super fast last week, and the new DTYA1s will be here tomorrow, so my experimenting with other clutch components is over, back to what I like best.
Love how the B/O torsional pressure at 6/1 is right in that zone of 14-16psi.
Dan
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Hi guys,just came back Monday night and when I got in,my Dalton O/B secondary spring was there on counter. Thanks Dale,now to remove some weight and get my rpms back to 9000 rpms,my boost pressure on my Koso x-2 is a tad high,but terry stated,it may be that way unless I size down my line,but its all good,now at least I know I am getting all I paid for,gauge reads 16.5 to 17 and its suppose to be 14.9 so its all there and my A/F is 11.7 WO and sled pulls hard,even though it was only pulling 8000 rpms WO on a 1/2 mile run on one of our local lakes,on crappy wind blown snow/ice it was still Gpsing 117 on stock 8jp belt,and when I had just my 8dn belt on,no other changes it was only good for 113 gps,so Dan you are correct 4 mph difference between two belts,all things the same,8000 rpms 113 8dn,8000 rpms 8jp 117 gps,with in 1/2 hr between belt changes temps around 30 degrees F yesterday snow wind blown hard,some ice in between,spinning hard,to much weight in primary,83 grms on 30/90 ulmer pink spring,STM straight 38 secondary on stock yellow spring at 70 degrees,love how that 38 pulls hard. Oh ya,my 8.5 rear wheels are coming out,they are hitting the transfer rad so hard,it is tearing up the wheels,and rubbing big bump in rod. Loss of speed there and grandpar wind screen on. lol
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I can see the 8DN being my trail ride/hi mile belt.....and then have an 8JP for radar running ect. Its alot tougher if you ride with other turbos though, lucky for me I ride with all 2s and being out front is a breeze.Hi guys,just came back Monday night and when I got in,my Dalton O/B secondary spring was there on counter. Thanks Dale,now to remove some weight and get my rpms back to 9000 rpms,my boost pressure on my Koso x-2 is a tad high,but terry stated,it may be that way unless I size down my line,but its all good,now at least I know I am getting all I paid for,gauge reads 16.5 to 17 and its suppose to be 14.9 so its all there and my A/F is 11.7 WO and sled pulls hard,even though it was only pulling 8000 rpms WO on a 1/2 mile run on one of our local lakes,on crappy wind blown snow/ice it was still Gpsing 117 on stock 8jp belt,and when I had just my 8dn belt on,no other changes it was only good for 113 gps,so Dan you are correct 4 mph difference between two belts,all things the same,8000 rpms 113 8dn,8000 rpms 8jp 117 gps,with in 1/2 hr between belt changes temps around 30 degrees F yesterday snow wind blown hard,some ice in between,spinning hard,to much weight in primary,83 grms on 30/90 ulmer pink spring,STM straight 38 secondary on stock yellow spring at 70 degrees,love how that 38 pulls hard. Oh ya,my 8.5 rear wheels are coming out,they are hitting the transfer rad so hard,it is tearing up the wheels,and rubbing big bump in rod. Loss of speed there and grandpar wind screen on. lol
My Ultimax text did not last long at all.....albeit the clutching was not what it should have been.
Dan
- Dec 4, 2004
- NS
- www.daltonindustries.com
Thanks.
Glad you got your stuff timely
alpineviper
- Aug 24, 2014
- Alpine Turbo Viper
is anyone running the dalton orange spring in a stock sidewinder? or are they for tuned sleds only
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Dalton secondary spring is a BLACK/ORANGE STRIPE (not to be mistaken for a fully orange TP)is anyone running the dalton orange spring in a stock sidewinder? or are they for tuned sleds only
IMO the B/O should work well with all Winders.
Dan
alpineviper
- Aug 24, 2014
What wrap should I use in a stock mtx? I also have qay 66 weights in it that are empty. And stock primary spring and stock 35deg helix with yellow spring. Wrapped at 3/3.
- 8K
