Destroying Belts
Churchill Falls ,NL
Canada
2015 Viper MTX
Why is my 2010 Nytro XTX blowing belts...
3 belts in the past 4 weeks everything seems to be in spec..even purchased a $160 ultimax XS belt 8 days ago ..gone on second ride..
:o| #$%&*
I had the same problem with mine it baffled me to ..Usually blew the belts over 90-95 mph for any length of time .. In the end i checked the air box and found oil in it and the drain from the air box has a tube that went right down beside the primary .. Figurered oil must of been spraying the clutch a bit cause it would feel like it would slip .. You do take it easy the first 20 -30 miles breaking the belt in
not saying this is the case, but I have to wonder how many belts are damaged loading trailer or getting stuck etc. my guess is those belts eventually blow. I've always been sure to go or not go, no inbetween. my belt has 5kmi on it now and still looks new. cant even remember what belt. xs maybe?
Usually get on average over 2000km on a belt, last weekend sled got stuck on truck and smoked the belt trying to unload it......sure as #*$&@ by end of day belt had shreaded
markowinnipeg said:
Usually get on average over 2000km on a belt, last weekend sled got stuck on truck and smoked the belt trying to unload it......sure as poop by end of day belt had shreaded
well, at least your honest with yourself. pretty easy for someone to blame the belt or the machine
spoke to a guy at dealer one time, showed me a OEM belt that was run 10k looked new. Told me a good long easy break-in was the best saver for belts. Stick with OEM, check the alingment and end play on secondary. should be good to go.
blown belt
thanks for the replys,,I have a 04 warrior with almost 18000 km and never had a belt blow apart on me...Hoping issue with Nytro isn't too serious..
that things rides as if it's 200 lbs lighter than my Warrior..keep you posted on outcome
clutch kit? had the same problem with my ulmers when i first installed it. root cause was belt slip. nothing worse than blowing a new belt in 100miles.
Make sure your getting good belt squeeze, belt slip/heat will kill them faster than anything. I'm still on my original belt (4750 K .5 mm wear)
Verify your alignment is correct. I bent my subframe which pushed my motor out of alignment and caused me to blow belts up constantly at any speed over 85 mph.
