skidoots
I did a search on blowing belts found a lot of guys are having the same thing that happened to me.. Two belts in about 100 miles
check you secondary spring for free height mine was short 10mm from stock (75mm)
make shure the clutch off set is in spec. 13.5mm to 16.5mm
I put a new spring in set the clutch to stock specs and rode 150 miles Saturday with no belt blowing. I like my Nytro now......
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Venting the sled would help alot to by keeping the belt cooler
yamahahaha
but you still shouldnt blow 2 belts in 100 miles. let the belt break in... for a half hour id say dont beat it to hard
bitchnblue09
Yeah come on, 2 belts in a 100 miles, WTF,there has to be a problem... I have almost 1600 on mine and its still in great shape, in fact, I have never blown a belt in about 35 years of riding, just replaced them when I thought they were getting glazed or to thin...
Outlander
I went to a Yamaha demo ride event last winter and had the belt on a fx Nytro shred on me on a ~1 mile test loop.
I've also seen this issue posted here by other members, too.
ryetarded
rode first 5600km without a break and then boom two in less than a 100kms
arteeex
What if your name was Belts...
2008FxNytro
- Oct 7, 2009
- Upstate, NY
- www.mpminc.net
skidoots said:I did a search on blowing belts found a lot of guys are having the same thing that happened to me.. Two belts in about 100 miles
I put a new spring in set the clutch to stock specs and rode 150 miles Saturday with no belt blowing. I like my Nytro now......![]()
How do you set the offset of the clutch??
skidoots
oem yamaha belts 8dn 01
oem yamaha 8dn- ]What if your name was Belts...[/quote]
sleddingfarmer
arteeex said:What if your name was Belts...
HA!
Mountaintech
2008FxNytro said:skidoots said:I did a search on blowing belts found a lot of guys are having the same thing that happened to me.. Two belts in about 100 miles
By shimming the secondary. Adding or removing shims (washers) behind the secondary.
2008FxNytro
- Oct 7, 2009
- Upstate, NY
- www.mpminc.net
Thanks.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
I take a straight edge on the backside of the primary (must be perfectly straight)...then use a mic between the back secondary (closed)and the straight edge...
with the bolt and shims installed on the secondary, there should be some float (if you subscribe in the float theory as set by yamaha) vs fixed theory
