NB-NYTRO
So is the statment below correct? and can I achieve it at 225lbs plus gear with a 5.5 spring?
You should have 40mm to 45mm of sit in. Caution!! do not preload the spring to less than 262mm or 10.3" when sled is off the ground as it will coil bind and cause dammage. If you are at 262mm and have more than 45mm of sit in you will likley need the optional spring.
