Does your Nytro start every time?
Has it??
  • Yes
    Votes: 0 0.0%
  • No
    Votes: 0 0.0%
  • Total voters
    0
Starting
Starts every time. I had it 1 time on saturday that it would not start. After I turned it on it's side :o| and it sat there till I got help to flip it track side down, it would not start. Let it sit and once the fuel pump cleared the air out of the line it started and ran great.
Guess the hill was too steep to ride from one side to the other.
in forty three hundred miles so far its only failed once, code 43, got down to forty below that night and was still 20 below when i went back and it started right up, i have been riding it since for over a month since the relays were on backorder and its started everytime since.
Type of gas
Last winter, sled diddn't start at the first turn of the key. Was running on premium gas. Since i've put it back on regular, it always starts now at the first turn of the key.
2500 or a few more, never has failed me yet, always starts-- turns over twice and BOOM shes ready to rock, from 28 below to 30 above , never a doubt- very dependable,great starting sled---- love it alot !!!---- "ZERO" problems with it "ZERO" cant complain about it at all!!!!!!!!!!!!
2008 FX Nytro Purchased Dec 08
Over 6000 miles
Never had any problem starting
Always stored in trailer at home, or outside with cover when we are away sledding.
Re: Type of gas
Same here. Used the sled all last year on regular and had no problems. This year I decided to use Preimum. First ride the sled would always start then shut off. After that I used regular and haven't had a problem since.
Just another reason why 4stroke is more efficient.......cheap gas. No need for the good stuff.
2008 RTX. I am having the fuel pump relay issue. I carry an extention cord and a hair dryer with me. Embarrassing and frustrating.
ms737 said:
Had issues with starting when left outside for a few days. Just Clicking when key turned. Glad I read this forum because was able to bypass the relay and get my sled home. -25 Celsius. The relay had moisture in it and when left outside it froze up. It's a known problem. Brought it in and replaced with no issues on warrantee. I don't think there's much you can do with this issue as it's internal to the relay. I had filled the plug with dielectric grease and siliconed the top of the male end to keep water out when in a shop to thaw out. Too much snow getting into the compartment due to bad air vent design. I put on a Frog Skinz filter patch. It should work. 2009 XTX 3000 kms
How do you bypass the relay? Is there a link to that forum?
I'm going to hold off voting till the end of the year but so far so good, just passed 600 miles.
I've never seen these relays.... That's a good thing I guess.
Can you just take a spare and put it in if it causes problems, or is it a major job to replace?? :rocks:
Oh yeah, what's pet screen??
relays
Turk said:
2 nytros.....3800 miles...started every single time even at -30 with out fail. They are outside nytro,s tho & really don,t get inside much!
heres a thought on the relays freezing. I wonder if there is any relation to ones that are outside all the time and those that get put away in a nice heated shop to thaw out . the ones going in the heat , the outside of the sleds thaw but maybe some condensate inside the relays really doesn`t get a chance to dry completely because of being enclosed ?then when get out in the cold they freeze up??? just a thought that came to mind when Turk stated that his were "outside " nytros .
800 miles on my 2010xtx stopped started to sputter looked at the gauge engine symbol flashing gave it a lil gas shut off restarted right up .noticed a couple times after idel go to give it the gas and a stumbel in it.not sure what the cause of this is.anybody else have this problem
