Berg570
- Nov 18, 2012
- Cle Elum, Wa
- Sidewinder MTX
On my '07 Apex, the seat always "pops" out from the tank cowling. Its about to rip if it happens again. I can lift the cowling and barely shove the seat under it, but I cant imagine this is right. The seat is tight otherwise.
I weigh 210 fully geared up, so Im fairly average. You might think a big guy could cause this. This sounds petty, I know, but I want my sled to look nice and its going to rip the seat.
Anyone ever have this problem? How do you remedy it?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Have you had your seat off. If so it may not be hooked under the tank lip.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Never had a problem with the seat, 260lbs geared up and ready to ride.
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
Something is messed up. Either the previous owner built up the seat/foam higher so it no longer fits correctly ...or pull the seat and check the "tabs" on the bottom side; the tabs should slide into the slots to keep the seat in place. It should look like this:
Berg570
- Nov 18, 2012
- Cle Elum, Wa
- Sidewinder MTX
rx1 man 04
- Oct 4, 2007
- ottawa
- 2007 Yamaha apex gt and 2012 Yamaha apex xtx
dont think its too much foam
looks like a misalignment problem, gotta be the seat or the cowling. I would say the seat. check the tabs on the seat to make sure they are not bent or broken. seat should fit in smoothly. I am lucky I still have my original seat after 7 years of riding, no rips or tears.
burnoutink
I had the opposite the plastic used to pop out on mine
yamahahaapex
mine fits in nice but its not snug, it can move with your hands and seems to bulge out right where the tunnel is? Doing that your boots also make the seat dirty there too so does anyone else have that problem?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
It looks very much like you missed a hook up front to me had done that before myself remove and reinstall seat or at least pull up on that corner it should feel very much attached if it is in proper if not it will pull up.
Yamahammer485
Lots of options here boys. #1, and likely the bigest range of motion you have between the tank and the seat is where the tank mounts to the tunnel, there is slotted holes in the tank plastic, allowing you to slide it more forward or back. In your case, your tank looks all the way back. Simply loosen the nuts off, and slide the tank forward. All the other plastics with move in unison to this. The other option is to check how your j-bolts are mounting to your exhaust sheild, the tabs may be bent or the shroud may have moved. This should work, but otherwise, you could shim the tank.
- 8K
