Turk
Tech Advisor
It is very easy & quick to change the primary set up from an unstudded sled to studded. The supertorquer weights...all of em..use a polaris/comet profile. that is the beauty of an adjustable weight...you can quickly & easily make changes for traction conditions. basic clutching 101.
Turk said:It is very easy & quick to change the primary set up from an unstudded sled to studded. The supertorquer weights...all of em..use a polaris/comet profile. that is the beauty of an adjustable weight...you can quickly & easily make changes for traction conditions. basic clutching 101.
Right Turk, as are the Heavy Hitters and Supertips. I think Im just a bit past the "basic clutching 101" stage of tuning knowledge.
**sj**
I hear ya...theat was the 40-10 hammertimes....the two speeds are billet steel now..
and the drag n flys are billet ONE PIECE DESIGN..
NOTHING MOVABLE!
but I hear ya..the "keep it simple stupid" deal
NOTHING MOVABLE!
sj said:I hear ya...theat was the 40-10 hammertimes....the two speeds are billet steel now..
NOTHING MOVABLE!
Right on. I deleted that post because it made it sound like the dran-n-flys were a two piece design.
Out of curiousity, what are you running for secondary cam and spring with those weights? Any issue with overshift?
Turk
Tech Advisor
I am accidently offending some people & will stop posting on this particular thread
Turk said:I am accidently offending some people & will stop posting on this particular thread
Not at all. You and I talked about this very topic at Haydays. We just have different aproaches to our clutching. All good Mike.
**sj**
limited run time...
stock cam with white spring so far ....
when the snow flies want to run dnfs with a stock oem style spring and close to empty weight...I will be running with a shallower exit angle..
BADSLED
- May 13, 2004
- Syracuse, NY
- 2012 Nytro MC Xpress 270
2011 Apex SE
2021 Sidewinder LTX SE - SOLD
BlueByYou2000 said:Turk said:I am accidently offending some people & will stop posting on this particular thread
That's too bad..... Both of you have a wealth of clutching knowledge to share. I have always enjoyed reading your posts on approaches to clutching and it's been a while since we have had a respectable, informative clutching debate on this site.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Anybody else do any more testing with these in an Apex?
SledFreak
- Feb 7, 2005
- Ontario. Canada
I see the guys on Dootalk are starting to look into these weights, since apparently all of the BRP race sleds are using these weights.
**sj**
I've done a little testing and love these weights! thanks scott...
what a setup to come!
ptt
Guest
sj said:I've done a little testing and love these weights! thanks scott...
Sounds like your happy
**sj**
I' love the heelclicker leveraged arm designed weights...dont care for the white spring...
a little tuning with yamaha springs yields great satifaction...
some minor tweaking still...but wow!
keep up the good work~!
1xr
sj said:I' love the heelclicker leveraged arm designed weights...dont care for the white spring...
Why don't you like the white crazy long spring? Does it coil bind?
**sj**
to me it's a tweaner spring...not race feeling like the red spring...I like the feel of less spring against less weight...less mechanical interference and smoother engagement..
