Snoxracer242
Why is this thing leaking oil out the air box, kind of embarrassing when this thing leaks oil onto the floor in my shop. What is causing this, oil level is in the middle of the cross hatches, so it is not over full. Where is the breather line coming from that is going to the air box? Any help of information would be great.
Thanks,
Dustin
Thanks,
Dustin
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2015 Viper X-TX LE MPI turbo
2009 Nytro XTX
There is a breathr hose that runs from your oil rez to your air box...have you rolled or tipped your sled over in the last little while??
GT03235
normally if you have oil coming out of a breather indicates a worn motor the crankcase is getting pressurised by piston ring blow by
arteeex
Or, you've tipped it on its side.
As you know the oil tank vent line goes into the air box. If you tip the sled (particularly to the left) oil will run into the air box and then out through the bottom ports.
It’s time to pop the filter element out, give it a bath and wipe out the air box.
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- SXV Venom, RTX Nytro, SR Viper RTX SE
- Maine
Arteeex is correct...Clean it out and that will atleast make it easier to see where the oils coming from...
Snoxracer242 said:Why is this thing leaking oil out the air box, kind of embarrassing when this thing leaks oil onto the floor in my shop. What is causing this, oil level is in the middle of the cross hatches, so it is not over full. Where is the breather line coming from that is going to the air box? Any help of information would be great.
Thanks,
Dustin
ditto upei...willing to bet you have rolled your sled over and it stayed there for a while....
Snoxracer242
No I have not rolled it over, not had it on its side, it is not over full of oil.
Just some drift busting, could all the bucking of the drifts cause it to slosh around and up to the vent? Just seems like quit a bit of oil that has come out of it to cause it to drip on the floor. And the machine only has 3100 miles on it so I would hope it wasn't a blow by issue.
Thanks for the replies!
Dustin
Dustin
gormleyflyer2002
Snoxracer242 said:No I have not rolled it over, not had it on its side, it is not over full of oil.
Dustin
yup......mine did it one when i hit a many miles section of giants whoops.....oil dump.
btw..........congrats on driving the snot out of your sled.
Scheidl
gormleyflyer2002 said:btw..........congrats on driving the snot out of your sled.Snoxracer242 said:
Dustin
LOVE IT!!
yamahahaha
ride it like a stolen donkey! I heard someone say it on here this week, thought it was funny
Scheidl
also, like a rented mule... lol
zeke66
Though I read somewhere that, if you have your oil topped right off, there is a possibility on big bumps/jumps the suction from the airbox could grab some oil. Maybe run the oil level in the middle of the marks or at the bottom?
Snoxracer242
btw..........congrats on driving the snot out of your sled. [/quote]
Thank You! I love blasting the drifts and pounding it to the max!
Apex809
My 08 same problem with only 830 miles. Damn motor better not be worn. I did alot of drift busting as well. Oil level is right on. And you can see it came from the breather. No worries there. There is a thread on here somewhere for the fix. Besides always wanted a Harley guess i got one now! lol
stinx
Neither my Harley or Nytro leak oil- yours must have been made at 4:59 on a Friday.
