Turboflash
- Mar 18, 2019
- Southern MN
I always extract pistons, scotchbrite them to mirror finish, and re-install. Make sure piston bore in caliper is also polished and smooth. Clean very well before assembling.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Side note, check your caliper where the pad rides. If it has indentations that’s are deep enough the Pistons in the caliper with start too gall, ruining the caliper and causing a leak. My caliper was worn @ 7k miles and pistons were shot. There should be a stainless steel pad that the brake shoes ride on instead of the aluminum caliper housing. This is what most vehicles use to keep the pads from wearing into the caliper.
Turboflash
- Mar 18, 2019
- Southern MN
Agree completely. Steel pad running on aluminum is not good.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Just took my my sled apart this morning to check if the retaining compound worked to hold the bearing inner race to shaft and it worked..bearing is on the shaft tight will need heat and a puller to remove!
When I did the original install cleaned the shaft and inner race of the bearing then I drilled 8 divets in the shaft and reinstalled with loctite bearing retaining compound 620!
Going to replace the bearings since the seal isn't holding the grease
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
Last I checked it was still good. That is now my Moms sled so it gets ridden pretty easy and doesn't get a ton of miles on it.Question. Has your driveshaft bearing inner race ever spun on shaft with that setup?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Going to replace the bearings since the seal isn't holding the greaseView attachment 154778 View attachment 154779
Managed to remove bearing it took lots of heat with a propane torch and a puller
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Here is the shaft with the loctite residue after heating it to removeManaged to remove bearing it took lots of heat with a propane torch and a pullerView attachment 154780
RAMSOMAIR
Marc, my bearing does the same and spits out grease after re-packing. This is actually from over-packing. Look at a brand new bearing and see how little grease is really in there. I always add more than they do but don't pack it right full!
Turboflash
- Mar 18, 2019
- Southern MN
Marc, you've seen this puller, right? Travis at BOP drew it up. It uses the 3 holes in the caliper housing. I made one out of 3/8" plate. Just tighten the 3 bolts a little at a time to keep plate flat on end of track shaft.Here is the shaft with the loctite residue after heating it to remove View attachment 154781
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
TOO much grease is bad also. As shown. Grease gets frothy if too much in there.
RAMSOMAIR
It also slows the balls down and they dont spin freely. This also causes heat build up and then spits the grease out like you are seeing.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I actually never repacked the original bearing last season because there was no sign of leakage! This is the original grease gushing outMarc, my bearing does the same and spits out grease after re-packing. This is actually from over-packing. Look at a brand new bearing and see how little grease is really in there. I always add more than they do but don't pack it right full!
RAMSOMAIR
Wow, way more grease than China bearing usually has lol.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
The picture is deceiving not much grease!Wow, way more grease than China bearing usually has lol.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
- 6K
- 6K
