The 998s that I know of with failed VRs were definitely newer then 2020...3 SWs and one Tcat...in fact 3 were 2022s and one 2023 SW. Only the Cat came with power steering.
Have a 2018 here. Came in because won't shift into reverse and has an intermittent electrical misfire.
Found out it has corrosion at ECU plug. I suspect this is something that rarely occurs, but thought I'd share. The active error code was P1689.
