yukonwarrior
- Mar 13, 2007
My lights started to dim and My sled barely started. Next I loose my guages and it won't build past 8000 rpm and chokes up when I give it full throttle then when I shut it off it don't start. Charge battery start it hook up meter to battery and it slowly looses voltage. check line to line resistance to stator and it seems to be within spec. Changed my rectifier with a used one off this site start it up idle it up to 4000 rpm and don't get the 14v @ 4000 rpm like the manual says. Do I have another bad rectifier or wrong one alltogether. The # on th original is FH001 3.5 151. The new ones # is FH001 2.7 231. What is my problem.
Also can I ride the sled with guages, lights, warmers unplugged and just use battery to start it. I wanna fix it but If I am waitin for parts again I wanna ride in the meantime.
Oh yeah it is an 04 rxwarrior stock and this happpened the day I removed the bar pad and installed a mtn strap??
