plake
- Apr 26, 2016
- Sheboygan
- Sidewinder LTX
What's up? Engine cuts out under hard acceleration and even backfired. No codes showing and runs fine when accelerating easy. You almost get thrown off, starts to pull really hard and cuts out.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
I would check your battery connections to start.
pipehead
- Feb 4, 2010
- Connaught
- Yamaha Sidewinder
I have the same problem it just started doing it
plake
- Apr 26, 2016
- Sheboygan
- Sidewinder LTX
The first 15-20 miles are fine then it starts doing it. Battery connections suggested??
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Whats the fuel level? Is it down on fuel in the tank, full or what?
It's what happens when they run out. That's why I'm asking. Could be fuel starvation under acceleration when low on fuel.
plake
- Apr 26, 2016
- Sheboygan
- Sidewinder LTX
Fuel 2/3 level.
KnappAttack
- Feb 19, 2004
- Welch MN
Possible revlimiter?
What are the RPM's when it happens?
Keith Schmitz
- Jan 12, 2015
- Dousman Wi
- APEX
I started a thread about this yesterday "I could use help"...is your clutching stock? I'm thinking (and hoping) it's my limiter, because it doesn't happen every time I accelerate hard.What's up? Engine cuts out under hard acceleration and even backfired. No codes showing and runs fine when accelerating easy. You almost get thrown off, starts to pull really hard and cuts out.
plake
- Apr 26, 2016
- Sheboygan
- Sidewinder LTX
I'm all stock. I'm not sure of RPM's but pretty sure it's not over. It hasn't accelerated long enough to over rev.
KnappAttack
- Feb 19, 2004
- Welch MN
If that's the case it sounds like it can only be a fuel delivery issue or possible electrical. If its electrical it would act like you hitting the kill switch and turning it on again, Fuel delivery will kinda surge, drop RPM but stay running and pop thru the intake kinda on and off type of deal.
plake
- Apr 26, 2016
- Sheboygan
- Sidewinder LTX
It's
like you hit the kill switch. I back off the throttle and it stays running.It's
plake
- Apr 26, 2016
- Sheboygan
- Sidewinder LTX
Anything to the break in chip thing that came from other post? I think it said it came from Yamaha.
Keith Schmitz
- Jan 12, 2015
- Dousman Wi
- APEX
I don't believe soAnything to the break in chip thing that came from other post? I think it said it came from Yamaha.
DC5
Could be rev limiter, the gauge is not fast enough so you can't see it, you need to use the max rpm recall to tell for sure
done dooin'_winder up
- Dec 6, 2016
- saegertown pa
- 2017 sidewinder stx 137 dx
what knapp said, sounds like fuel pump. not enough fuel pressure for wot.If that's the case it sounds like it can only be a fuel delivery issue or possible electrical. If its electrical it would act like you hitting the kill switch and turning it on again, Fuel delivery will kinda surge, drop RPM but stay running and pop thru the intake kinda on and off type of deal.
