snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
I don't believe there is any kind of break in chip or any thing in that direction. All that Mike Knapp suggested would be where I would look first. What does your dealer say? How many miles are on any of these sleds effected by this problem?Anything to the break in chip thing that came from other post? I think it said it came from Yamaha.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
Definatly no break in chips. We've broke two in this year and they go like hell with 0 miles on them
no code, loss of gauge cluster?
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
It sounds like it's cutting spark for some reason. It could be the crank trigger or ecu.or anything in between.
Use that warranty man.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
It's
like you hit the kill switch. I back off the throttle and it stays running.
Really need to know what RPM range it's happening at. If it goes lean RPM will be down and it will surge and pop.
You should check the clutchs and belt just to make sure there is no oil on it. If there is, it could easily be rev-limiter. If they are clean and spotless, I'd tend to think its not getting the fuel the engine needs. The reason I say that is you mentioned a backfire, and I assume that backfire is in the intake which is lean popping in the intake.
I haven't seen or heard anyone find the limiter yet myself.
Anyone else hit the limiter yet at all?
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Just thinking , did you have good supreme 91 octane in it.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
After market exhaust? If so, Youre bouncing off the Rev limiter
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
I see a post on here about retourque of the primary clutch. Could it possibly be that the clutch is slipping on the crankshaft causing to motor to quickly overrev hitting the limiter. This might explain why it doesn't happen all the time and only happen when accelerating hard. I'd follow the suggest re-tourque procedure.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Good theory Jay...
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
Its sad the Sidewinders doesnt come with A/F gauge so we can read the a/f. I will say its a must in a turbo engine. If it goes lean the top gasget can go ore a rod comes out of the engine.
plake
- Apr 26, 2016
- Sheboygan
- Sidewinder LTX
I'm all stock. 140 miles on and good fuel, non ethanol.
plake
- Apr 26, 2016
- Sheboygan
- Sidewinder LTX
Getting ticked, give me my Apex back, it was flawless.
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
roadking
- Jan 8, 2017
- minnesota
- Yamaha sidewinder
just got back from black hills 420 miles, first 150 miles I experienced engine cut out after that no issues, ran it up to 120 mph.
Scottyvodka
- Dec 31, 2016
- Ct
- Apex xtx
Sidewinder Ltx
Kept my apex just in case.Getting ticked, give me my Apex back, it was flawless.
- 6K
