Nightwing
- Sep 11, 2005
Hello folks:
I own a 2005 Grizzly 660 ATV with the ITP XTR 27" tire kit. After riding the kit for about 10 months now, I decided to try a clutch kit from EPI. I had it installed today by the dealer and noticed that the engine idles at what seems to be a much higher speed than before installation of the clutch kit. As soon as I hit the electric start, it takes off pretty high.
Is this normal? Should I return to the dealer and have them check the idle or something else?
Thanks,
Nightwing
Thanks,
Nightwing
You can turn the idle down on the side of the carb with the black knob....pull the left side panel.
Nightwing
- Sep 11, 2005
Thanks for the reply MrSled
I noticed that I had the choke on, which also means I had my head up my you know what. I don't remember turning it on when I loaded it up from the dealer and/or turning it on when I started it and rode last night after the installation of the clutch kit. Perhaps someone at the dealer turned it on.
I assumed the high idle was a byproduct of the clutch kit. Stupid me.
Nightwing
Nightwing
LOL...no problem, it happens
Ganz
I was going to tell you to check that this morning but I thought naaw he had to have checked that.
Glad you got it figured out.
- 148K
