YamaSpark
- Sep 21, 2017
- Greenfield, Minnesota
- 2016 SR VIPER S-TX 137 DX
Here's the canbus plug disconnected from the EPS motor on a 2024 Winder.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
These are the guys that figured it out.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I wonder if they would just sell you the whole "kit"?
Tcat100
- Jan 16, 2019
- Chicago
- ZR9000
Guys, all the information is right here in this thread, other than the measurements on where to drill the 3 holes. I will try to get that if I can. If you are not mechanically inclined, any dealer should be able to do it for you, or better yet, an independent powersport shop. It does take a fair amount of time and skill to get through it the first time. The second time much faster...
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Interesting that this can be done on the SRVipers as it was never a factory option.
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
Same chassisInteresting that this can be done on the SRVipers as it was never a factory option.
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
So what's the all in $$$ for oem parts? Can a dealer do this in 5 hrs if they've done it before?Guys, all the information is right here in this thread, other than the measurements on where to drill the 3 holes. I will try to get that if I can. If you are not mechanically inclined, any dealer should be able to do it for you, or better yet, an independent powersport shop. It does take a fair amount of time and skill to get through it the first time. The second time much faster...
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
It’s about $1600 USD if you need a new wiring harness (I would says it’s required for older than 2019). 2019 and newer it’s about $1100 usd from partzilla if you source connectors and splice into factory harness which is what I did.So what's the all in $$$ for oem parts? Can a dealer do this in 5 hrs if they've done it before?
The parts are probably more expensive from other dealers. I noticed Arctic cat parts are more (about $2200 vs $1600). As mentioned before, it’s all itemized here in this thread.
I would imagine a dealer could do it in 5 hrs….if they have done it before and willing to do it.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
Right, but i was wondering if the SRViper ECU would support it.Same chassis
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
At this point, it does not appear that the ECU is involved. None of the ECUs on older model winders are aware of the EPS that has been added on. They seem to work.
Tcat100
- Jan 16, 2019
- Chicago
- ZR9000
I sure hope I can use this power steering this year given the snow situation!
Tcat100
- Jan 16, 2019
- Chicago
- ZR9000
I've taken the measurements for the 3 bolts you need to drill for.
This does not cover the relocation of the voltage regulator to the front of the tub, the exact whereabouts of that is not critical - just need to get it out of the way.
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
Finally got out to ride my 2019 after doing the conversion. It's the best money I have spent on my sled (besides the QS3R upgrades)! I tapped into the CANBUS harness and the EPS works fine, zero issues. I personally love the feel of the earlier model spindles and adding EPS, I feel I have the ultimate sled. Swapped some Slydog Command skis and it handles great!
Thanks for all the information in this thread and also TCAT100 for the detailed specs on where to drill (I could have used that earlier!)
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Thanks Richard for sharing!
Tcat100
- Jan 16, 2019
- Chicago
- ZR9000
Sorry my sleds were 400 miles away. I tested my 19 RR that I did this on over the weekend. Rode 50 miles. Behaves identically to my 22. Great win for guys wanting to upgrade IMO. Now let's see if Cat can keep up with the parts orders!Finally got out to ride my 2019 after doing the conversion. It's the best money I have spent on my sled (besides the QS3R upgrades)! I tapped into the CANBUS harness and the EPS works fine, zero issues. I personally love the feel of the earlier model spindles and adding EPS, I feel I have the ultimate sled. Swapped some Slydog Command skis and it handles great!
PS. I love how you can add aggressive skis and carbide with no impact to your arms. I'm running Curves with 8" shapers
