Error codes in the FAQ section ?
w8tn4snow
Upstate NY
2015 SR Viper LTX DX
I was wondering what i have to do to be able to view the codes ?.
When i click on it it boots me out of TY .
I ran my sled with the headlight pod unplugged and now i get 2 error codes , kinda wondering what they are ?
It says ER_2 then ER_1 , keeps flashing back and forth between 2 and 1 .
Thanks .
code Item Symptom
ER-1 ECU internal malfucyion No signal are received from
(output signal error) the ECU
Er-2 ECU internal malfuction No signals are received from
(output signal error) the ECU within the specified
duration
hope this helps
sounds like at bad connection
This is the message i get when i try to download the file in the FAQ section ,
" Sorry but you are not authorized to view or download this Attachment "
Am i missing something or was this link supose to work for everyone ?
If you are looking the FAQ. section not sure. Go to frequently asked questions at to of this page by Swiss Sledder. Go to Error Codes and down load from there. I just did it and it worked for me.
But on your specific codes EEr 1 EER 2 won't be on there. it only gives you codes from 11 up to 80 something i think. For those two codes you have to look in the manual on above said pages. Do a search on i think its Phazer nut. He has a link to the manual you can down load.
Let us know how it works out. I have had the pod of mine all summer and have been running every other week so i expect to get the same codes when i put it back on.
cheers
I figured out my problem , the wires in the small guage pod plug came out of the plug when i took it apart . I must have put the wires back in wrong . I had the blue and green wires swapped . . Found it and the error code disapearred . Thanks to all those who gave advice on the issue . As always a great place to find helplful info ! ;)!
