Bob Miller said:steve 05 RX-1 said:I rode 150 miles and the drain cap was full.Im going to put a longer clear line on it.I also used the factory catch tank along with the evac setup.
There is a factory catch tank? Is this something that has to be drained if you have the stock air box on?
Red-RX said:The factory catch tank is the little black plastic tank located in front of the engine on the left side. The factory "EVAC" system consist of a hose which connects the engine crank case to the catch tank. From the catch tank there is a hose that goes to the air box. There is no easy way to drain the factory catch tank.
