Evo power up
trevorl1
Nova Scotia
Canada
2014 sr viper xtx-se
I just sent out my ecu for the stage 4 evo flash and also ordered the evo header.
Talked to Jim on the phone seems like a great guy to deal with.
I'll have pictures posted of when I get everything here and installed hopefully I will get a nice Christmas gift and it comes before the break.
I already have a sandale muffler and will be going with either the venom clutch kit or ulmer.
I'm leaning towards ulmer since it comes with a helix.
Or option three since I live close to dalton, buy the adjustable QAY weights from them and a helix.
I have the QAY 70 in my turbo, I had them in and wasn't happy with them and put 8FS in. 8FS lacked adjustability without rivets so I took the QAY 70 and cut the bump off the heel to flatten them out and really like them now. I hate to have my 4 stroke over rev on takeoff.
Jim at EVO is a great guy!
Just talked to Jim, EVO and Thunder Products are working together and Jim is now selling Thunder Products Big Venom Kits :)
Now you can get an EVO Performance Flash, EVO Header and /or muffler and a clutch kit all at the same place.
I had the 2.5 flash done and it was a 1 week turn around from the day I sent it out. I was very pleased with the whole process, the guys at EVO are great.
Aside from that I have a FrankenTune - COTC (modified) - Machined Clutches (Ulmer) - Airbox Mod (Ulmer) - Trail Can (MBRP) Most of it was done last year.
Being an early adopter is a blessing and a curse. You get to the mods real fast and learn a ton about the sled - but you still need to do a bunch of testing/tweaking etc. and will find yourself buying/swapping components to get it just right.
Yes and it's a lot of fun making it better. My wife doesn't understand"it's a guy thing". You can't just leave it alone .❄️❄️
Dianne threatened me with things I dare not repeat here if I touch her sled any more..............................
Well I'll need to talk back to Jim about the clutch kit, I could buy the venom clutch kit and just order myself a helix from dalton, I'm sure someone on here knows what I would need.
I told my riding buddy that has a 800 e-tec about my mods, I could almost keep up now he'll be in my dust.
Something like a 46/42, 45/41 or something like that would really get you a holeshot and then use the power on top end
I just talked to EVO and the big venom clutch kits will be 399$ from them.
I think I'm going to try to build my own clutch kit since the stupid Canadian dollar isn't worth a thing.
I'm thinking I will go with the Dalton weights.
How much weight are you guys running with the EVO stage 4 package?
I am running turbo at 10k altitude so not same as you and would be a wild guess but here is what I have
1. QAY 70 bump cut off ramp and backside ground down to get to 68 grams
2. Stock secondary with 40/46 helix (turbo helix not for N/A)
3. BOP soft start spring with 6mm of primary clutch shims (substitute Green/white/green for BOP if needed)
That's mine for 210/275 horsepower - around 9k on 210 and around 9600 on 275
does anyone know the rate of the ulmer helix .i have one and it says k on it
Trevor - I am running the stage 4 and going to be doing some tesing on snow (when we get it), but I believe NA sleds with the Big Venom kit and EVO Performance flash will be around 50-51? What ever I end up with....I will be shooting for 9,350 -9,400 total rpm
Anyone running evo's 87 octane tune.
Putting the EVO 87 performance ECU flash in buddah's sled tonight. Going to make a video on the EVO flash start up and idle compared to the 2015 flash start up and idle.
K helix is a 49/41
so how will it work with the venom kit this k helix .right now I'm using the stock viper helix .thank you
