Have been in contact with Aaron Excell on using an under tunnel exhaust on my attack. Want to add a boss seat, but not sure what to do with the back part of tunnel, heat exchanger and hoses that will be left exposed. I have not seen a Boss seat for an attack on Boss web site so i am a little lost at what will happen at the rear end of the sled. Any one help me before i spend all this money and tear my sled apart?
That mountain sled still had stock exhaust. With the under tunnel mount I will have some voids behind the seat. I guess I was thinking of a Boss shorty type seat. I might have to fabercate a tunnel cover from the seat back. Anyone else have any ideas?
Red2003
just contact BOSS. They can build yuo whatever yuo need for a seat. If you want a solid seat without that leftover void, they can do that easy.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
You can either go with Boss or a Mountain Mod seat.
here is what I did with mine. Just made a block off plate where the stock exhaust sat and contoured it into the stock tunnle. Then made a seat brace for the stock seat. And just used a simple piece of 1/2 x 1/2 alum angle to make a mount for the stock tail light to mount under the seat. Looks great in person. Eric
