Daranello
Suspended
That's great!!! Make the selection a tad easier
The Excell site says 400rpm's more...does that mean the top end RPMs will be around 9500rpms. Since I'm running my best speeds at 9100rpms right now???
Srxspec said:The Excell header has stepped tube technology which will pick up more in the low and midrange than the MBRP style header. Excell has lowered their price as of today to $499.95!
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Yes you will have to add weight to your weights as the rev limiter will kick in at 9400 rpm.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Srxspec said:Yes you will have to add weight to your weights as the rev limiter will kick in at 9400 rpm.
will the ignition module overide or raise the rev limiter?
also...for the full system with filter and pc3...has the map changed or evolved from early on....or is it still the same?
Stoli
I have the Excell header pipe and it cracked. Nothing a tig welder couldnt fix, i just need to look at just how the custom mounts i have as we believe it is too rigid for my setup. Looked at Ulmers display at Haydays and it looks like they re-enforced this section on the new ones.
Please please do not take this as saying thier craftmanship is junk or anything like that. I really like the sound of it and am like homer simpson in a donut shop waiting for enough snow so i can start rippin it up.
If you are going to buy one off the classified or a used one - something to note.
- Apr 17, 2003
- Menno, SD
- Menno, SD
StoliDoli, you need to contact Excell. There is a sleave that slides over that area and then gets welded on to help strengthen it.
Stoli
Srxspec said:StoliDoli, you need to contact Excell. There is a sleave that slides over that area and then gets welded on to help strengthen it.
sent PM - Thanks
- Apr 17, 2003
- Menno, SD
- Menno, SD
SledFreak said:Sweet, did you get my PM?
Got it, but you are number 37 on my list of PM's to return! LOL! I will hopefully get to it tonight or tomorrow morning.
sj said:will the ignition module overide or raise the rev limiter?
Yes the ignition module has the ability to move the rev limiter up to 9900 rpm.
Map was updated last year for the full system setup.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
if able to run 9500 and not loose too much surely would gain some top end / ground speed!
arteeex
sj said:if able to run 9900 and not loose too much surely would gain some top end / ground speed!
You might lose a rod or a valve, either of which can have a serious impact on your top end.
Daranello
Suspended
ttt
Nikolai
I have an Excell vector header and LeoVince exhaust(for 1000 GSXR) and it made a very noticeable difference in power.
NLVMAX
- Jan 18, 2008
I have the full Excell system and you can certainly notice the extra power. Very happy!
Phyxius74
Nikolai said:I have an Excell vector header and LeoVince exhaust(for 1000 GSXR) and it made a very noticeable difference in power.
Does the Vector header fit an FX nytro?
Nikolai
Yes it does and it comes straight back which makes building your own exhaust a lot easier.
dirk660
i have an mbrp can on my nytro right now and was wanting to put a header and maybe some k&n's on it. is there a header i could use with these and not have to use a tuner.
- 9K
