Ndoggct
- Aug 25, 2018
- Ct
- Looking for 18 sidewinder
hello I switched out my 6 exhaust bolts and wondering if everyone using lock washers or just going with regular 8x1.25 bolt? Thank you
Stormbringer
- Jun 5, 2018
- Valparaiso Indiana
- 18 sidewinder rtx 15 viper rtx
I would say no, but I am not sure. I installed stainless steel studs, along with copper coated flange nuts.
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
Just went the bolts no lock washer.....and of course the anti sieze.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Yes, SS lockwashers and SS bolts, and the MUST is the nickel anti-seize. And then you dont crank them down too hard/tight IMO.
Mine removed with ease this season, and I always replace with NEW washers and bolts each time i install. Peace of mind that it wont snap next removal.
See my build thread link in SIG or click here: https://ty4stroke.com/threads/my-rtx-le-50th-build-thread-rockerdan.149801/#post-1384052
RAMSOMAIR
Ceramic Never Seez
Be Careful with the cheap Chinese grade Stainless bolts. They stretch and they shear easy too. I believe the torque spec is 9 ft lbs on the exhaust bolts.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
I replaced mine with more of the same stock torx head bolts. After 5 or so removals they were looking pretty sad. Some looked partially bent while others looked like they may have started to twist a bit, so whereas I copied someone’s idea from TY and made a tool for the 2 tough ones, I stayed with the stock torx.
Whatever you use, it’s a must to stay on top of these, multiple times each season. Copper anti seize is not enough, so nickel or ceramic is a must!
Pstn head
Yes... 9 ft lbs then 18 ft lbsBe Careful with the cheap Chinese grade Stainless bolts. They stretch and they shear easy too. I believe the torque spec is 9 ft lbs on the exhaust bolts.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I've been reading about this issue in the "frequently asked questions" section
Is this still.a issue for.2019? I haven't removed the muffler uet
Pstn head
Not so much an issue... Like most any equast bolt some tend to cease more than others. More preventive maintenance than anything else, remove bolts apply high temp antizieze and reinstall. I been good getting a few times out of the bolts before installing new ones, but I run the bolt in and out of the threads gently before retighining. Imo torquing these bolts are important.I've been reading about this issue in the "frequently asked questions" section
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Thanks i will pull it apart next week and do what you recommend!Not so much an issue... Like most any equast bolt some tend to cease more than others. More preventive maintenance than anything else, remove bolts apply high temp antizieze and reinstall. I been good getting a few times out of the bolts before installing new ones, but I run the bolt in and out of the threads gently before retighining. Imo torquing these bolts are important.
Is there a gasket like the viper has on muffler?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
A word of caution on ceramic never or anti-seize. I bought a bottle of the supposed “best” white ceramic stuff last year and when I went to take the bolts out, or I should say tried to take the bolts out, you guessed it, they seized, it turned to powder and jammed the bolts where they wouldn’t turn in or out. I ended up stripping the threads right off the bolt itself. I used regular copper anti-seize mixed with a bit of alum anti seieze the next time and never had a problem at all after that. I got lucky the threads come off the bolts and not out of the turbo!
I’ll never use the hi temp ceramic anti-seize again! Might as well throw dirt and lime dust on the bolts and assemble. Lesson learned.
Pstn head
I agree with KnappAttack... I use the copper and works good. The gasket is reusable for a bunch of times, it's a copper gasket I believe but non the less reusable.Thanks i will pull it apart next week and do what you recommend!
Also a little trick is to warm up the sled to normal operating temperature, instead of using heat via a torch. The first time do a dry run cool motor so your not rushing after warming up motor and your familiar with the task.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
SS is also very soft too...chinese or not, they can shear easily....why I do not crank down on them too much at all....removed my twice now, and with the nickel anti-seize they just easily turn out, not effected at all by the heat.Be Careful with the cheap Chinese grade Stainless bolts. They stretch and they shear easy too. I believe the torque spec is 9 ft lbs on the exhaust bolts.
I still bought a box full, so I can replace them just about every time I remove.
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Ive used the nickel anti-seize that I posted for 3 seasons now, a zillion heat cycles and its the only stuff ill use as I know mine come out so easily. I cannot comment on ceramic or copper, And wont use any other as I still have so much of the first can I bought from canadian tire...
Dan
Dan
- 6K
