exhaust removal
snappy
mass
whats involved in removing the exhaust end to end?mine broke at the H pipe.has anybody welded these with succes?03 rx1erle
I have a stock exhaust system if you're interested, you have to take the seat off, and it's easier if you take the top rear suspension bolts out in order to get more room for your hands to loosen the exhaust clamps
ex
the two exh clamps can be lossened from the top. just take the two nuts off that hold the gas tank down rase the gas tank and you will find two rubber plugs remove there is were you get at the 12mm bolts on the clamps. just back off the bolts and with the other mounting bolts at the rear remove the exh should just slide out the back.
make sure you have new gaskets for it....and The trick is when you put the clamps back on....put the bolt in with the clamp (clamp position that allow the boat to go in easy/in the wrong position then tighten up the clamp.....(this makes the clamp round again and it fits to the pipe correctly) then loosed the bolt/remove it and put the clamp in the position you originaly removed it from then put the bolt back in and tighten it up.......sounds wacked but trust me this help....the bolt are not long so if the clamp is out of shape is a real pain in the well you know......keep this in mind when doing the work and you will see what I mean...
also I have an mpi exhaust that it coated if you want it 250 or best offer
Rock on
