Moving along... I dropped the skid down and removed the stock shocks. Adapting the lower mount should be rather easy, using the same adapter type Fox supplies to mount the float on various machines. The upper mount will require removing the spherical bearing from the float and having a small bushing machined and pressed in. The bushing might be little thin, the mounting hole is a little larger than the upper shaft.
Hopefully the dampening will be within range.
There's no snow in sight around here, though with my sled in pieces that might change.
