F/S Aftermarket Goodies : Apex, Vector Nytro, Phazer, RX-1, SR Viper... Updated 9/10/20
my wife has a 2010 vector ltx and would like to sit higher, they say the newer vectors seat is higher, do you have anything that would help her, and still look stock, her sled is red thanks gary
PM's sent.
Got 3 sets of SS y pipes from an RX-1 that have been modified to fit the Apex and Attak from 06-10. We weld an extension onto them so they are a direct fit onto the apex. $200 for a set.
Also got an OFT 2 wheel axle kit, and OFT steering relocate.
Updated 10/1/14
RX-1/Apex/Vector parts
(1) set of rx/Rs tall mirrors with mount...50
(1) sets of apex & 08+ vector side panel mounted mirrors....40 for pair
(1) sets of gytr clickers for apex,vector, attak, rage...400 for set
std fox floats for vectors and apex....350
apex/vector a arm guards....35
mono shock with hygear re-valve and dual rate spring…..400
(2) Large rear cooler heat exchanger for an attak, rage, ltx or mt sled….250
Factory Yamaha cover….85
Yamaheater plug and play. No boost…..100
New extroverts on used shaft….130
Excell SS headers…..350
(4) sets of SS rx-1 y pipes modified to fit apex…..250 per set
Ohlins mono shock with cable. Plug and play into any 06-10 apex…300
Apex seats. Great easy upgrade for rx-1 and 05-07 Vectors…..275
Misc
black spoked yamaha accessory idler wheels with replaceable bearings....15 each
(2) "yamaha" foam handle bar pads....12
(4) sets of low snow wheels and mounts. ..50 per set
(1) set of low snow wheels for 136 mono (middle of rail on stiffener)….50
47/43 helix…35
Hauk “H” Helix….35
Bender 70/20 Helix….35
Skis/skags
black pilots....150
(3 sets) new 8" carbide runners....35 per set
(4 sets) used dual runner carbides/dually....40 per set
Yamaha mountain skis….150
Nytro Parts
OFT 2 wheel axle kit…..50
New extroverts on a used shaft…130
Med chrome windshield....60
Small chrome windshield... 25
Med shield with side deflectors…75
(1) xtx gytr rear bumper...75
(1) short track gytr rear bumper....75
set of blue footrests....40
white skid plate....65
(2) red skid plates....65
(1) yellow skid plate…65
gytr clicker shocks....475. Just rebuilt
Gytr clickers...400
black billet aluminum top handlebar clamp (says FX Nytro)….20
Phazer parts
set of mirrors for phazer that clamp onto phazer windshield bracket....$60
Stock 14” x 144 track. No missing lugs ...$400
Gytr skinz muffler.....100
Excell Phazer Pipe…250
Yamaha radiator fan…75
R6 fans with hardware to install…45
Factory Yamaha cover…85
Tracks
(2) 121 fully clipped ripsaw witih 96 studs like new!….400
121 ripsaw witih 96 studs…275
121 ripsaw fully clipped. Drilled for 96 but no studs…..300
Found a 13mm sway bar for an apex/vector/rx-1 while removing a bulkhead today.....$70
Will the extroverts for the apex allow you to run a 1.75 track without modifications?
Id like to see a picture of the oft 2 wheel axle kit if thats ok.
Updated 11/2/14
(3) sets of gytr clickers for apex, vector, attak, rage...400 for set
(3) std fox floats for vectors and apex....350
carbon fiber apex/vector a arm guards....35
(2) mono shock with hygear re-valve and dual rate spring…..350
Factory Yamaha cover. Like new….100
Excell stainless steel headers…..325
(4) sets stainless steel rx-1 y pipes modified to fit apex…..250 per set
Ohlins mono shock with cable. Plug and play into any 06-10 apex…475
(3) 06-10 apex windshield bags….20
(1) new Carlisle ultimax belt……50 each
(1) set of Yamaha soft carbon fiber/black handguards….30 per set
(1) set of Yamaha hand guard mounts and mirrors…50
Excell Muffler complete with plastic for 06-10 Apex…..375
Rx1/ Vector Map & Tank bag…60
Rx1/Vector Windshield bag….20
Rx1/Vector Mirror set with mounting bracket…50
(2) 06-10 apex/ 08-15 vector used tall windshields with support bars….65
(1) new 06-10 apex/ 08-15 vector used tall windshields with support bars….100
Misc
(2) Blue large rear 7” rear idlers with replaceable bearings…25 each
(6) Blue spoked accessory small idler wheel with replaceable bearings….15 each
(4) sets of low snow wheels and mounts. ..45 per set
(1) set of low snow wheels for 136 mono (middle of rail on stiffener)….45
47/43 helix…35
Hauk “H” Helix….35
Billet aluminum blue gas cap…50
1 set of dupont slides for 121 mono…75
Skis/skags
black pilots....150
(1) set of all Black curve xs skis with runners and leading edge…350
(1) set of all black curve xs skis with runners….325
Yamaha VK utilliy skis….6” wide…$150
(1) new set of woody’s slim jim duallies…150
(1) new set of woodys std duallies…150
Nytro Parts
Gytr clickers...400
Fox floats…400
Phazer parts
Got a bunch of new sleds in. Below are some goodies on them. Will add them to the main list with prices soon. Feel free to PM ahead of of time if you see something you want.
2" riser block for rx-1
excell water temp gauge
yamaheater from 06 apex
Whal brother extroverts on pre 09 shaft
12 used excel x wheels
low snow wheel kit for attak
black curve xs skis with leading edge
black c/a razors
yamaha mt skis
fox floats for rx-1 or nytro
mountain mod all black seat
136 ice riper xt. excellent shape
121 ice ripper xt (less than 100 miles)
135 ripssaw fully clipped ( couple hundered miles)
136 hartman tunnel extension
136 hartman rail extensions for 121 rx-1
hygear revalved mono shock with dual rate spring
hygear revalved and dual rate spring gytr clickers
I've decided to maintain a thread with a list of all the aftermarket goodies that I strip off of sleds.
Updated 10/1/14
(1) used bulkhead saver.....100
Misc
47/43 helix…35
Hauk “H” Helix….35
Skis/skags
black pilots....150
Nytro Parts
Gytr clickers...400
Phazer parts
Tracks
Do you still have the medium shield w/deflectors
