fault codes and diagnostic mode
apex4
Quispamsis nb
what is the differenance....between fault codes and diagnostic mode........I had an issue code came up on screen was code 36.....did my diagontic test code 36 is injector #1 ....my sled has the same feeling as everyone here thought it was coil pack fault code 36??? any ensight before i call dealer..whom will just give me the run around! :o|
I can say that i havent seen anyone with a bad injector?
It must be a bad connection ,or a bad coil.it can be a bad injector but.....
swap coil around to see if the code changes to the other cylinder.
