finally part of the boost club
wantboost
upstate ny
after running nitrous for a year i recently bought a stage 2 bender turbo sled.have some bugs to work out but happy to be part of the club now.anyone have any install instructions for the bender system?also there is a main jet in my charge tube.whats that for
wantboost,
The main jet in the charge tube is to meter boost to the pitot tube / carb float bowls. That is the fuel mixture adjustment I was telling you about previously. There is a spot to thread in and store a spare also.
The bigger the number, the leaner she'll be. Bleeds the boost off from the floatbowls = less pressure.
Might want an A/F ratio meter...
Without a A/F meter you have no reliable way of tuning the motor.
Make the investment ...fast! Call Ted!!
The bender kit should have exhaust bung already installed and pluged awaiting the O2 sensor. It's not a hard install. Just a pain taking things apart.
PS: The main jet you see on top of the charge tube is for storage of a spare main jet. You have to reach under the charge tube for the one that actually functions.
otis on the hallman boost control for 12lbs light or heavy spring?i have a wideband but i let srxguy use it.what a friend i am.see if i can get 1 from ted today for the weekend.
If your going to Lake Morey I can bring one with me.
If you buy the ProRX you get both springs.
Ted.
