wantboost
after running nitrous for a year i recently bought a stage 2 bender turbo sled.have some bugs to work out but happy to be part of the club now.anyone have any install instructions for the bender system?also there is a main jet in my charge tube.whats that for
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
wantboost,
The main jet in the charge tube is to meter boost to the pitot tube / carb float bowls. That is the fuel mixture adjustment I was telling you about previously. There is a spot to thread in and store a spare also.
wantboost
what jet are people using.i think this one is 760
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
The bigger the number, the leaner she'll be. Bleeds the boost off from the floatbowls = less pressure.
Might want an A/F ratio meter...
wantboost
so don't adjust carb jets,work with the charge tube jet?
Otis RX
Without a A/F meter you have no reliable way of tuning the motor.
Make the investment ...fast! Call Ted!!
The bender kit should have exhaust bung already installed and pluged awaiting the O2 sensor. It's not a hard install. Just a pain taking things apart.
PS: The main jet you see on top of the charge tube is for storage of a spare main jet. You have to reach under the charge tube for the one that actually functions.
wantboost
otis on the hallman boost control for 12lbs light or heavy spring?i have a wideband but i let srxguy use it.what a friend i am.see if i can get 1 from ted today for the weekend.
Ted Jannetty
wantboost said:otis on the hallman boost control for 12lbs light or heavy spring?i have a wideband but i let srxguy use it.what a friend i am.see if i can get 1 from ted today for the weekend.
If your going to Lake Morey I can bring one with me.
If you buy the ProRX you get both springs.
Ted.
wantboost
ted i'll call you in alittle while.can i get it for fri ups?
srxguy
order it now, it will be here tomorrow
Ted Jannetty
wantboost said:ted i'll call you in alittle while.can i get it for fri ups?
I need your zip to check if your 1 day UPS ground or 2 days.
srxguy
Ted Jannetty
srxguy said:12302
2 days regular ground, according to UPS Chart, even though sometimes it gets there in 1 day.
So Next Day air is the only way to garantee.
srxguy
Yea, I usually got my stuff in 1 day from ya but ya never know.
