First ride on a turbo! OMG!!!
I'm certain you can tune a sled as you've helped me get mine just the way I wanted it.....but can you tune a fish.....lol
I await your side by side comparisons once you get snow and the parts you require.....don't understand the super high collar on that coat as most men I know have no necks....
that was an reo speed wagan record .you can tune a piano but you can't tune a fish . ck out the sw coats ,you''ll see .we need cold. than i can test more i have some real good stuff for th 850s .
Good memory on the REO.......
There you go again on the 850....lol......don't you know you can cause a panic "dooing" that in here....lol
Doesn't! Sorry.
It's very soft, off idle and down low. The engagement is unbelievably smooth. So I'm fine with it.
Even a hit at 20mph is not strong. Give it a tap at 40+, a very linear powerful pull until you run out of real estate.
Somewhere between 20 & 40 there's a sweet spot. I didn't make time to find that out.
Doesn't! Sorry.
Mine felt the same way. I checked the secondary spring it was set at 3-3. Put it up to 6-1 but I have no more snow to test.
Maybe you could try this and see if it helps any;)!
i had yamahas back in the 70s and still do .as you know,im not bias and my sw makes 180 sleds to date that i've owned .
the ramp is just to plain flat ,great trail sled other wise .
Ya that's true. I have a few sets of Dalton weights I'm going to try but just wanted to changed one thing at a time to monitor results. Wrapping the secondary will help it back shift a little better though!!
Do I need that fixed? Lol! The engagement was so smooth, not abrupt at all.
I didn't say anything about changing engagement. You can have smooth engagement and great low end acceleration which you said was soft.
Keep us in the loop with any changes you make.. thanks!!
