yamadooski
I just bought a 2007 Attak GT that they did clutch work on. I called and found out they put in CR10ek plugs and worked the primary and secondary as well as a spped ring on the secondary. Has anyone had experience with their set up? Any info on what to expect would be appreciated.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
check the belt width....if its 2-3mm wider then a stoxk 8dn,then you have their wide drive kit....which comes with speed ring,and split collar...
the belt still LOOKS like stock belt and even has same number(8dn ect)....but its actually wider,if its the wide belt kit.
if it is....you need to be sure to use their belt always...as stock belt wont work well at all...
Dan
Dan
And try and by the Belt by itself LOL from FIX GOOD LUCK waited 7 WEEKS so far and this was from a guy i told people was awesome to deal with, how a summer changes people this guy is a DEADBEAT his name is Tim hes one of the Owners
yamadooski
Fix
Try this link. I haven't ordered from them before but heard good things aobut them on TY.
http://www.yamahasportsplaza.com/pages/ ... vbelt.aspx
