manitoban
I didn't think yami's broke!I can speed up slowly to 6000 rpm,but as soon as i give quick throttle-it surges,then i have to let the engine idle down to speed up again??I tried to read the manual,but limited for time-because my sled is stuck in the bottom of a drainage ditch 12 miles from home-so i would like to bring it home soon before it's too dark!!Can anyone help me=thanks alot
rancidjo
http://www.ty4stroke.com/viewtopic.php?t=83992
TORS is kicking in, probably because of your speed sensor
my 06 nytro acted the excact same way when I forgot to plug in my speed sensor after a track install/summer teardown
check for damaged speed sensor, broken wires on speed sensor, bad connection
speed sensor can be damaged by bad driveshaft bearing, blown belt, collision etc.
If you can't find the problem, try by-passing TORS to get you home, just be careful incase your throttle sticks
doo_man
I rolled mine in some slush....and for whatever reason throttle control filled with ice/water/slush and wouldn't work kept throwing code....chiseled off ice and messed with throttle till it worked.
manitoban
so,it may be ice build up around speed sensor?If so,why is this not weather proofed?=thanks by the way!
Snowman07
Sounds like the speedo sensor bearing is shot. Happen to me 3 weeks ago. Pull the clutch side panels off and look at the speen sensor below your secondary. If the speed sensor is touching your shaft, then the bearing is shot. Gonna cost ya about $300 to replace if a dealer does it. About $100 in parts.
manitoban
Hit the nail on the head guys!Bearing gone and worn through speed sensor!How often does this need to be replaced?Second one in 3500 miles!Didn't think this was the problem"Again"!!!!!! This is another example of warranty being important-our Can. Division is way less out of pocket =where by the USA has many more years available to the customer.Almost makes us buy in the USA, and have a second address, and support American Dealers!!!Whom, I wonder if this is happening?
rancidjo
that bearing needs to be cleaned and repacked with grease at least once a season, but I usually do mine 2-3 times
rancidjo
would be nice if yamaha put a greasable bearing with a zerk in that location
manitoban
Now your talken!Don't give this idea for free!!Sell it to the manufacturers
I just had this code combo flashing on mine this morning...the sled had just come back from being at Dyntech for a dyno session....I picked it up at the shop ( sat outside covered last night )..fired it up and had those codes flashing....wouldn't move ( damn TORS )...I wiggled the throttle cable...shut it off..started it back up and codes gone...sled is fine now...do I need to get these codes cleared or will they creep back up....Im going on a trip this week and have no time to get it to a dealer.
Snowman07
Codes clear themselves so long as the problems don't come back. If the codes stay on then you have serious problems.
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
Make sure your throttle cable is all the way back in the hole by the thumb throttle, sometimes it seems to be in but if you push just a little harder it will kind-of click, and lock in more. It needs to be setting all the way back to make the tors work right
mach9
shaddow44 said:I just had this code combo flashing on mine this morning...the sled had just come back from being at Dyntech for a dyno session....I picked it up at the shop
Did Hindle offer up a smile for you after the dyno session?
mach9 said:shaddow44 said:I just had this code combo flashing on mine this morning...the sled had just come back from being at Dyntech for a dyno session....I picked it up at the shop
Lol, He's been at a bike show so I can't tell if he's smiling.
SIMMER
Snowman07 said:Sounds like the speedo sensor bearing is shot. Happen to me 3 weeks ago. Pull the clutch side panels off and look at the speen sensor below your secondary. If the speed sensor is touching your shaft, then the bearing is shot. Gonna cost ya about $300 to replace if a dealer does it. About $100 in parts.
I found this post the other night when the exact same thing happened to my buddy. Turns out the speedo bearing was mangled and it took out the speed sensor. Good info because if we caught it a bit earlier there wouldn't have been as much damage. I actually had an extra bearing with me but by the time we checked it the bearing was welded to the shaft.....result.....tow truck home.
