found an extra part!
Burlington, Wi
While taking my gas tank off I found a plastic cap on top of the valve cover. I checked all the vacuum caps on the throttle bodies and they are in place. I followed the vacuum lines and did not locate where it came from. Does any one have any ideas where this cap might belong?
Pictures are worth a 1000 words +
There's a pretty good chance it was dropped in there on the assembly line (especially if you say all the vaccum caps are in place). I've found the random nut/bolt laying inside my sled after I bought it too wondering the same thing...where did this come from.
What have you installed for accessories?
Did you recently install a tunnel heat exchanger? It looks like the bleeder valve cap.
Thanks, I was wondering were that ran off to. Just throw it in the mail when you get a chance.
Yes look just under your rad and see if the bleeder cap is, is, is in the picture. Good call and once again to you Arteeex, Thank you very much for that auto cad on the tunnel block. Looks and fits awesome after install and perhaps no more Baby Huey's flying out!!!
When I go to friends houses' to work on their sleds I usually go to my shop first, and find an important looking bolt or something. So I can pretend to pull it out of the sled later and say "Uh oh, where the heck did this come from?"
Its a good time!
Its a good time!
buahhahahahahaha!!! I do this to! what a riot!!
Looks like a cap from the throttle bodies. The vacum block off cap. That's my guess for today!
