dansranger
While taking my gas tank off I found a plastic cap on top of the valve cover. I checked all the vacuum caps on the throttle bodies and they are in place. I followed the vacuum lines and did not locate where it came from. Does any one have any ideas where this cap might belong?
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Pictures are worth a 1000 words +
vogelm1
There's a pretty good chance it was dropped in there on the assembly line (especially if you say all the vaccum caps are in place). I've found the random nut/bolt laying inside my sled after I bought it too wondering the same thing...where did this come from.
canoehead
- Jan 14, 2011
- NE, Alberta
What have you installed for accessories?
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Did you recently install a tunnel heat exchanger? It looks like the bleeder valve cap.
arteeex
Thanks, I was wondering were that ran off to. Just throw it in the mail when you get a chance.
canoehead
- Jan 14, 2011
- NE, Alberta
Yes look just under your rad and see if the bleeder cap is, is, is in the picture. Good call and once again to you Arteeex, Thank you very much for that auto cad on the tunnel block. Looks and fits awesome after install and perhaps no more Baby Huey's flying out!!!Grimm said:Did you recently install a tunnel heat exchanger? It looks like the bleeder valve cap.
dansranger
It's not the Heat exchanger bleeder cap.
I forgot about that cap. Thanks for the input.
sherlock29
caliper bleed screw cover?
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Hey, I found a cap like that laying in my trailer this weekend.
Its 0,75" wide and 1" deep.
Anyone figured out where it belongs?
sleddingfarmer
When I go to friends houses' to work on their sleds I usually go to my shop first, and find an important looking bolt or something. So I can pretend to pull it out of the sled later and say "Uh oh, where the heck did this come from?"
Its a good time!
Its a good time!
dansranger
its not the brake bleeder cap.
natedawgedog
- Feb 5, 2011
- DLG, Ak
- something from 2019!
sleddingfarmer said:When I go to friends houses' to work on their sleds I usually go to my shop first, and find an important looking bolt or something. So I can pretend to pull it out of the sled later and say "Uh oh, where the heck did this come from?"
Its a good time!
buahhahahahahaha!!! I do this to! what a riot!!
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
What is the size of the cap you found? Is it a small hole in the top of it?
towerrigger
Looks like a cap from the throttle bodies. The vacum block off cap. That's my guess for today!
