driftrunner
So my brother and I are putting on new tracks on our Nytros and we discover that the the bolt that hold the lower gear assembly on is snapped off and rolling around in the chain case cover behind the outer bearing. The rest of the bolt is still in the driver axel. What is up with this? Anyone seen this before?
Zakre
most common problem on the nytro almost lol, there is updates for it, new bolt or bolt and spacer.
towerrigger
Leave the broken bolt in there and re assemble without. Or use an easy out to take the broken bolt out and get the new updated bolt. My 08 broke 2 before I finally took 1/16th off the end. My 10 has not broken it yet. 2500km on it. Lots of guys running without the bolt.
viperguy
My dealer new nothing about this problem. Didn't know any thing about a updated bolt.
snomaniac
Mine was the same way I left it in there, no telling how many of the 2800 miles on my sled that it was that way. There are guys on here that have over 5k running with it broken off. Run it.
driftrunner
I got the broken end out of the driver shaft, I will talk to the dealer about an updated bolt. thanks for the help.
NFLD-Nytro
I don't know how you could ever get that thing back together without the bolt. I can't imagine what a pain that would be.
The broken bolt comes out really easily using an easy-out.
MMStewy
- Jan 11, 2008
Agree with all of the above.
The only guys that don't have this problem are the guys that haven't opened up their chaincase yet.
LSXM3
MMStewy said:Agree with all of the above.
yet
i couldnt agree more, when i did my track swap i was like no way i am going to have a broken bolt....then it was like son of a
i guess im not getting this done today, dealer had to order the bolt and it took 3 days!canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Unless you guys are putting the bolts in with spacers you'll see this problem again.LSXM3 said:MMStewy said:Agree with all of the above.
yet
Nine2Nine
NFLD-Nytro said:I don't know how you could ever get that thing back together without the bolt. I can't imagine what a pain that would be.
Not that bad actually.
NFLD-Nytro
Nine2Nine said:NFLD-Nytro said:I don't know how you could ever get that thing back together without the bolt. I can't imagine what a pain that would be.
Well, I tried to put mine back together without the bolt, and couldn't do it. My hat's off to you. It's just too bad I can't give you a call for some help with reassembly when I run into trouble.
Nine2Nine
NFLD-Nytro said:Nine2Nine said:NFLD-Nytro said:I don't know how you could ever get that thing back together without the bolt. I can't imagine what a pain that would be.
Well, I tried to put mine back together without the bolt, and couldn't do it. My hat's off to you. It's just too bad I can't give you a call for some help with reassembly when I run into trouble.![]()
There is a tool called " Patience " hard to find at my place but works well. You just have to get the reverse fork in place and all will feel right. And you don't have to worry about spacers and bolts doing a dance in your chain-case. There are many on this site willing to help.
09Nytro_XTX
I just changed my fluid but didnt takr the chain case cover off. Sled has 1700 miles.. Is that going to tear something up if i leave it the way it is???
Dano
Anybody with a 2010 have this issue?
Bolt is broke on my apex and still have to fix it. A bit of JB weld should fix the hole in chain case cover.
Dan
Dan
