Mountain riding versus trail/moguls is quite different. Also valving plays a key role.
I had Carver revalve mine. In talking with mike we discussed how most run low air pressure to try to compensate for stiff valving.
In my case I run 80 psi main and 130 evol IIRC. This may not be bad for you especially if you are liking more spring in the skid. Best part about this is you can always change easily.
