Boston RX1
Has anyone ever studded this track? I love the track, but have come to the decision that I must stud.
Ruggybuggy
- Sep 1, 2013
- Kenora, NWOnt, Canada
- 2007 Phazer FX 144
Why do you think you must stud? Most of the guys running the freeride on this forum don't bother.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Why must you have studs?
I think you are just asking for trouble if you try and stud this track. Does anyone make studs long enough to work on a 1.5"? If so, IMO you are going to have issues with tearing the studs out and bending them over because of the stud length.
G.B.
G.B.
Pockets
when you go that long of stud you HAVE to use the extra long nuts or your wasting your time and will just destroy the studs
Lumpyboy
- Jan 25, 2014
So, did you end up studding? When my current track gets clapped out I am thinking of the 1.5 Freeride. Ride mostly groomed trails but also some single track in deeper conditions.
3wheelerdude
- Jan 6, 2010
- Ottawa Ontario
- 2019 Voyageur 600
2019 ZR200
1991 Ovation 340
1986 XLV 540
Previous sleds: 1996 Vmax600, 2007 Phazer, 2016 Bearcat 3000
I have a studded 2 inch track and it works well. Sure you need the proper nuts and backers, but dont let anyone scare you, it can be done with good results.
ViperMan
- Jan 4, 2004
- Binghamton, NY
- 2014 SR Viper RTX
I had the Freeride 1.5 studded and it worked incredible with no issues. Did some of the tips break? Yes. Did some of the studs bend? Of coarse. I've never owned a studded sled in which this didn't happen. Nature of the beast. Did any of the studs rip out or tear track? No. The most important thing (again, as with any studded track) is to re-tighten the studs after the first few rides and then to periodically inspect and replace/ re-tighten if need be. And as Pockets said, the extra long nuts are required.
phazme
Go ahead and stud it did my 136 right out of the box. Just leave about a 1 1/2 in the center . This prevents stud heads from hitting center shock.
