BLUEBALLER
- Jan 29, 2005
RSD said:Isn't it all the play (slop) in the front end that's causing most of the problems? or have you guys fixed that?
I had new lower balljoints installed last week to get rid of some of it. Uppers weren't too bad, but did have some play. Next is oilite bushings for both a-arms. should be good n tight after that.
yamaha did come out with the update but it wasn't OFFICIAL.
sounds like you're getting a handle on that thing BB, good thing you have more patience than I do, hope we meet up some day, I'd like to try it out.
Ike
- Aug 20, 2005
- Sodankylä, Finnish Lapland
- Other
- Vmax-4 MountainMax 800
BLUEBALLER said:A BIG thank you to IKE for giving me the heads up to this MOD!!![]()
Anyone else see the same results??
You´re welcome!
Hey this is what this forum is all about.
Ike
bigdave
- Dec 18, 2003
- sylvan lake, Michigan
- 14 Viper LTX SE, 14 Viper RTX SE , 08 FX Nytro , 07 FX Phazer, SOON 2017 Sidewinder LTX LE Blue
front Geo
Hey were are you guys getting the oilite bushings or are you machining them your self????
Fasttoys
Re: front Geo
call ulmer racing they have them 6053872833
bigdave said:Hey were are you guys getting the oilite bushings or are you machining them your self????
Whiplash
Just want to thank everybody that put time and effort into this front end mod. THANKS! Will have mine done soon.
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
This might sound dumb, but cant you shim the lowers out 2.5mm?
I havent noticed that shimmy at that speed, but usually I'm either faster than that, or slower than that. Most of my miles are on the trails in Munising, but I din't notice much after flipping and shimming the rubbers. Would it be worth it to wait and see what the '09 update will be?
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
nate007 said:This might sound dumb, but cant you shim the lowers out 2.5mm?
The lowers are fixed/non-adjustable. I assume the spherical ball joint is held in with a c-clip or something.
BLUEBALLER
- Jan 29, 2005
Crewchief47 said:nate007 said:This might sound dumb, but cant you shim the lowers out 2.5mm?
Yes, pressed into the a-arm and held in with a c-clip.
When I was there, the service tech. asked another if it mattered which way he put it in, and the guy said no, just pop it in there.
gormleyflyer2002
BLUEBALLER said:Crewchief47 said:nate007 said:This might sound dumb, but cant you shim the lowers out 2.5mm?
well thats a mistake IMO....the ball joint is teflon lined on one side, I'm sure it has a certain side up/down etc...?
nytro boy
has anyone else done this mod with the upper balljoints, machining 2.5 mil off and if so did u have the same results as blueballer
Reaper
- Nov 10, 2005
- Starbuck, Manitoba
- 2014 SR Viper XTX. COTC, Hygear 141 pro link.
I did works fantastic, see my respone in the topic.
1st yamaha
I just got back from riding with 2.5mm ball joint mod and the floats revalved air psi 80, the front end is close to perfect works very good on all trail conditions at all speeds. Over 2000 miles I never felt safe at high speeds on small studders the front would bounce all over the trail making it a hand full to ride. The front end is working like it should. It's better then my Rev-X. -happy at last-
Ike
- Aug 20, 2005
- Other
Glad to hear that mod works over there too.
Ike
Ike
BLUEBALLER
- Jan 29, 2005
Over 1000 miles with this mod and I can't say thank you enough times.
I went from hating the damn handling in the corners to loving it. Almost perfect IMO. once the slop is eliminated in the front end, I will be one happy cowboy.
Inside ski lift is almost eliminated and the sled actually RAILS around corners, even on hardpacked groomed trails. Gone is the twitchy, quirky handling in the corners and through the whoops. Way more predictable and actually quite fun to ride hard!
To those debating doing this. DO IT!!! if you don't like it, buy some new upper balljoints as they're probably all slopped out anyways. If my uppers are replaced on warranty(which they probably will be), the first thing I'll be doing is this mod again. It worked that good.
There is a reason why Yamaha made 11 modifications to the 09 front ends. Because the handling was not up to par on the 08's. I would be willing to bet this mod was one of them.
It took over 3000 kms to finally figure out how to make the sled perform as it should have from the factory, but I'm happy now.
thanks again Ike and Yamaha Finland
