ericmichael
tried starting my sled tonight in about 20 below hauled it ouside to jump start it..as you know for one man pulling on one of these is a chore. now I pulled the green starter relay out warmed it up inside, pulled the relay up front fuel pump or something warmed that up...charged the battery. still getting code 12 wont turn over...i'm having a hard time to type this my hands are so cold...needless to say i'm P^*&ed off that I couldn;t ride tonight. Seems like the thing has to be in a 80 deg. garage to run and not all of us have the money for that...i just dont get it
SledFreak
- Feb 7, 2005
- Ontario. Canada
Can you here the fuel pump?
Gibby
I do believe that code 12 is crankshaft sensor and is unable to start with this code.
I am no help on what to look or how to fix.
Gibby
Gibby
ericmichael
yup..when it usually does it I just warm it up and its fine..when its close to starting it'll make a loud clicking noise then turn over..but tonight..NOTHING..and i believe it was because I was stuck outside and not in my little snowmobile shack with a silent glow..but I couldn't haul it back in there..so its sitting outside for the night..hopeit likes it.SledFreak said:Can you here the fuel pump?
ericmichael
Gibby said:I do believe that code 12 is crankshaft sensor and is unable to start with this code.
Gibby
Thanks for your input though. and yes i've read that a million times..its one of those relays but I dont understand because I brought them in the house for 20 mins and warmed them up..still noithing..but when it was in the shed it was turning over so I hauled it outside so I could get my truck close enough to put the cables on and nothing.
Gibby
On mine when it does not start on very cold morning i usually cycle the key a few times, then crank it over.
Someone on here suggested it and seemed to work for me.
Gibby
Gibby
craigwsrx
- Feb 19, 2007
- Fenton Mi.
- 2017 Sidewinder 27,000 miles
2009 Nytro xtx 31,000 miles
2006 Attak 26,500 miles
2003 RX1 13,500 miles
2000 Mountain Max 14,000 miles
1998 SRX Mountain 17,000 miles
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
Mine did not start on cold mornings. Solenoid would click but would not pass juice. Changed starter solenoid and corrected problem.
ericmichael
where is that located?craigwsrx said:Mine did not start on cold mornings. Solenoid would click but would not pass juice. Changed starter solenoid and corrected problem.
LazyBastard
It there is any logic to the design, it should be right beside the battery. If not, follow the big red wire until you find it.
ericmichael
LazyBastard said:It there is any logic to the design, it should be right beside the battery. If not, follow the big red wire until you find it.
Replaced the starter relay assembly for $41 and I dont have any problems anymore..its nice not having to have it in a warm garage before every ride or come out from the restraunt and have it not start..
Blue 4's Rule
Curious as to why you wouldn't have replaced this before! There are lots of threads on this! Not saying this to be an #*$&@ at all either. Relays are cheap & I always carry a couple of spare ones in my pack at all times! WAY to simple a fix to not be ready for! Anyway, glad you got it sorted out at least!
ericmichael
Blue 4's Rule said:Curious as to why you wouldn't have replaced this before! There are lots of threads on this! Not saying this to be an #*$&@ at all either. Relays are cheap & I always carry a couple of spare ones in my pack at all times! WAY to simple a fix to not be ready for! Anyway, glad you got it sorted out at least!
I haven't had the net for over a year, just recently had them come and run all the wires at my new location etc. so I had some catching up to do!
