hank
- Jan 23, 2006
- Iowa
- '16 RsVector XTX 1.75
'07 Phazer GT
'16 Phazer RTX
I have a 2010 Vector LTX with ~3400 miles.
The rear skid is essentially stuck in one position, won't extend -- won't compress.
There doesn't seem to be any visual damage to the skid.
At 3000 miles, I had the sled in for service and the dealer pulled the skid to change the hyfax. In the process, the mechanic damaged one of the boots that covers the dial adjust linkage and they replaced the boot as part of the service.
Any idea what has happened and is it possible that faulty service is the source of the problem?
Thanks.
Thanks.
radianguy
- Jan 1, 2007
Sounds like the shock may be frozen, have you had it in a heated environment then back in the cold?
I experienced a similar thing with my sled once, had it in the shop overnight( heated) when I took it home and put it in my shed( unheated) I experienced the same thing next ride. Took 5-10 minutes to free up.
greenthumb
radianguy said:Sounds like the shock may be frozen
I'd agree.
Dump a pitcher of hot water on it and see if it frees up. Works for me.
If that's the problem; the oil is contaminated with water and needs a change.
Dara
- Jan 24, 2007
- Sault Ste Marie, Ontario, Canada
Pulled the skid to change the Hyfax?
hank
- Jan 23, 2006
- Iowa
'07 Phazer GT
'16 Phazer RTX
Thanks for the quick replies.
I've had the sled in my heated garage since my last ride 2 weeks ago so frozen was a poor choice of words.
The suspension is basically stuck in the middle of it's travel. I can pick up the rear bumper to where the suspension extends and the track leaves the ground but when I let go it falls right back down and even if I jump on the running boards there is very little give.
I suspect that the shock has failed but I'm unsure of the failure modes and really want to know what I'm getting into before I take it back to my sled "unfriendly" dealership.
I can see the transfer rod extend/retract - is this correct?
Yes, the dealer pulled the skid to replace the hyfax. I was tight on time and didn't know that was what they were going to do until I got the call that they damaged a boot reinstalling the skid :-(
Need help in Iowa.
Need help in Iowa.
MCApex44
- Mar 30, 2006
- Western New York, Chautauqua County
- 2014 Viper RTX SE (sold)
Hank...is the sled sitting on the ground or do you have it on those sled Dolly's ?
hank
- Jan 23, 2006
- Iowa
'07 Phazer GT
'16 Phazer RTX
The sled is sitting on dollies.
3wheelerdude
- Jan 6, 2010
- Ottawa Ontario
- 2019 Voyageur 600
2019 ZR200
1991 Ovation 340
1986 XLV 540
Previous sleds: 1996 Vmax600, 2007 Phazer, 2016 Bearcat 3000
Happenned to my old Phazer. Shock was jammed in one position. Even when heated up, it would not move. Ended up replacing the shock as it was not serviceable.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
hank said:The sled is sitting on dollies.
Take it off the dollies. Every year this same question/concern gets asked and that is all it ends up being.
I don't quite understand how it affects it with the dollies other than it slightly compressing the skid at that point, but it does make a difference.
Also curious when the last time this skid seen a grease gun?
I do mine usually after every local ride and it is surprising the amount of water you can push out each time.
09nytro
hank
- Jan 23, 2006
- Iowa
'07 Phazer GT
'16 Phazer RTX
Thanks Irv,
You were absolutely correct - it was due to the fact that the sled was sitting on dollies. Pulled the dollies out and back to normal.
I grease the sled 2 to 3 times during the season.
Hank
Hank
MCApex44
- Mar 30, 2006
Irv said:hank said:The sled is sitting on dollies.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
MCApex deserves the thanks Hank, I was just repeating what he said and through in my 2 cents based on what I have also heard.hank said:Thanks Irv,
Hank
Glad to hear that's all it was.
- 9K
- 42K
