Fuel and NO2 tuning
stoutner
Seneca Falls, NY
Website
www.ecsexpress.com
I just ordered my boondocker NO2 kit for my Apex. I also ordered seperately an O2 sensor and fuel/air gauge. Is this how you guys are tuning fuel?
What fuel/air ratios are optimum on an otherwise stock Apex?
Should you try to keep the ratio the same throughout RPM range and should it be the same on the Nos as off?
Any other tuning/performance tips for an Apex would be appreciated. :nos :die
I hope you ordered a 'WIDEBAND' O2 setup....
Piston wash on a 4 stroke?
well not wash but carbon from over fueling=rich. totally blue on the band of the plug or round band at the tip=lean. over fueling will most will give you a bog just lean it out from there.
