yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 12 Nytro XTX (mine)
06 Apex GT (wifes)
07 Phazer (#2 sons)
02 Viper (#1 Sons)
Does the 2012 Nytro have the updated relay’s?
Mine are all black, bought the sled last spring.
Want to change out if needed.
up dated ones are red. my 16 apex has the up dated one. my 11 is still running the stock one.
yamahinn03
- Dec 28, 2004
- oshkosh, wi
06 Apex GT (wifes)
07 Phazer (#2 sons)
02 Viper (#1 Sons)
Mine are all black on the 2012, planning on changing it out while weather is nice, sucks when its 10 below an out on the trail, no start. Good thing We where at a tavern, tried changing it out but wasnt sure which one it was, so went inside an got a cup of hot water an poured if on them, she fired right up..
Then... The wife’s Apex did the same thing. Another cup of hot water an away we went.
Both got swapped out the next day.
smokingcrater
No easy way to figure out which is which, as apparently the position is random. They aren't overly fun to change, not much room to get your hand in there! With any luck the 3 you need to replace are the 3 closest to the front.
You can figure out which one it is by turning key on and hearing and feeling which one clicks. Normally does it even when it’s not working to power up fuel pump.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Replace the fuel , load and fan relays with the solid state update. The 4th relay is the headlight high/low beam control which has a different pin out than the others and can't be replaced with the SSR update.
If you still would like to know the location of each relay then go by the wire color codes:
