Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Going to tackle this and looking for updates.
1) Has the 1/4" elbow & grommet from Cat still working for the most part?
2) is it better to run 5/16"?
3) not exactly sure about plastic & ethanol?
It seems as though whichever fitting you choose would be submerged in fuel & under slight pressure for the first gallon or so from full tank.
Thank you.....
Thank you.....
Fords4life
- Dec 7, 2021
- South Dakota
Go metal or plastic, dont matter as far as material breaking down, yes it will be subjected to fuel and slight tank presure for about the first 3 to 4 gallons, just sit on the seat when tank is full and it pushes gas out the fill neck, .25" gas line works fine if fittings are only .25", i drill my fittings larger internaly for max flow, a 90 degree bend always reduces flow is why i drill larger, and best to use a fitting with a barb to hook a hose on to, to direct fuel return flow into basket un abstructed.
Doc Harley
- Oct 17, 2016
- Here & there
So, a push in style grommet & elbow works good enough. No need for bulkhead style?Go metal or plastic, dont matter as far as material breaking down, yes it will be subjected to fuel and slight tank presure for about the first 3 to 4 gallons, just sit on the seat when tank is full and it pushes gas out the fill neck, .25" gas line works fine if fittings are only .25", i drill my fittings larger internaly for max flow, a 90 degree bend always reduces flow is why i drill larger, and best to use a fitting with a barb to hook a hose on to, to direct fuel return flow into basket un abstructed.
Thank you.....
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
3 gallons or less in your tank!!
Hello all. Anyone having any run issues with 3 gallons or less in the fuel tank?AND OR say about 85-90 miles on a tank? I have a theory as to what happens to mine and wondering if anyone has hesitation/ popping like a backfire/ knock lights on hard pulls. Or say starting and stopping fast with...
ty4stroke.com
Been running this mod for thousands of miles. No issues..
Some reading for you and links to parts. Its kind of long but lots of good info. I use the orange grommets. Planning to replace the grommet every 2 seasons. I did check my 2022 this year as this mod was done form zero miles.. All good after first season with mod.
If you get into a jam . PM me
Doc Harley
- Oct 17, 2016
- Here & there
Yep, read all 23/4 pages last night. Wasn't sure if people had updates to it and didn't post. Old thread...3 gallons or less in your tank!!
Hello all. Anyone having any run issues with 3 gallons or less in the fuel tank?AND OR say about 85-90 miles on a tank? I have a theory as to what happens to mine and wondering if anyone has hesitation/ popping like a backfire/ knock lights on hard pulls. Or say starting and stopping fast with...ty4stroke.com
Thanks Jon
Fords4life
- Dec 7, 2021
- South Dakota
Push in works just fine, only thing i have seen is the factory black rubber grommet degrades over time ( weather checks) replaced my grommet this fall after 2 seasons.So, a push in style grommet & elbow works good enough. No need for bulkhead style?
Thank you.....
Doc Harley
- Oct 17, 2016
- Here & there
Right on. I'll get them ordered.Push in works just fine, only thing i have seen is the factory black rubber grommet degrades over time ( weather checks) replaced my grommet this fall after 2 seasons.
Thanks Brendan!!
Hopefully this is the last thing I've overlooked, for now.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Viton Fuel Tank Grommet - Wicks Aircraft Parts
Self sealing grommet for use with tank mount valves and elbow fitting. Made of Viton for superior fuel resistance and compatibility. Requires 33/64" mounting hole. Fits FV- 11046 and the FV-11032 and is required for installation.
www.wicksaircraft.com
These are a better material for fuel..
- 36K
