- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Recognizing the need to be price conscious and that not everyone has $5,000+ to spend on turbo kits. Ulmer Racing has been working hard to lower costs and bring sledders a great all around trail package with good useable horsepower! With that we will have more information available on this new kit, but here are a few details.
Ulmer Racing FX Nytro 180 Kit
Included in the kit:
Available options:
Other options that will be available and we have not set pricing on yet:
- 8.5 gallon Trail Tank (100+ mile range)
Ceramic coated cast iron header and down pipe
Ceramic coated turbo exhaust housing
Ceramic coated heat shields
GT2554R dual ball bearing turbo
Dynojet Power Commander III
Multi Function Hub
Exhaust enters into the stock muffler
Stock muffler = quieter than stock
Intercooler
Run 5 lbs of boost & 180 HP @ 8800 rpm on premium pump fuel
This setup runs on a stock motor and usually takes 8 hours to install.
Priced at $3,999.99
Available options:
- AEM Air/Fuel Ratio Gauge: $300
Boost Gauge: $55
***Gauge prices include gauge cup to mount gauge.***
Clutch Kit & Gearing Package : $250
- Upgrade to Power Commander V
Upgrade to LCD Screen with Boost, Air/Fuel Ratio, RPM, and MPH
Electronic boost control (should you get bad fuel or a spot where only 87 octane is available you will be able to flip a toggle switch and adjust the boost down to 3 lbs of boost).
skoalring11
with the turbos on the market now do you have to change the head gasket? With this turbo is there any modifications to the motor?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Stock motor
thetruck454
Nice!
stopdropanroll
If someone were to buy this kit then want to upgrade to the 215HP kit (stage2) in a year or so could it be done, and how much (roughfly) would it be. Also I checked out your display at Hay Days and noticed no BOV, can one be added to it (stage 1 or 2)?
- Apr 17, 2003
- Menno, SD
- Menno, SD
The turbo used in the 180 kit could be taken up to 8 lbs of boost (210ish hp) but not any further than that. In order to do that you would need fuel pump & regulator upgrade ($400), ignition module ($325), and a different style of muffler ($250-300 depending on what you choose).
We do not see any benefit in a blow off valve at or below 10 lbs of boost. One could be easily added to the lower tank on the intercooler though.
stopdropanroll
Srxspec said:The turbo used in the 180 kit could be taken up to 8 lbs of boost (210ish hp) but not any further than that. In order to do that you would need fuel pump & regulator upgrade ($400), ignition module ($325), and a different style of muffler ($250-300 depending on what you choose).
Thanks, any long term effect of that turbo running 8psi, I just wouldn't want to push something too hard. Also if I were to get boost crazy and want to build on the kit more could a turbo be swaped even further down the road. Its a pretty large investment and I just want to understand if I would have to scrap the whole thing to get crazy, and I would be runniing a undertunnel Jardne muffler, so wouldn't need to upgrade hopefully.
- Apr 17, 2003
- Menno, SD
- Menno, SD
The GT2554 (used in the 180 kit) will be just fine at 8 lbs, just won't be capable of anything past that. You could upgrade to the GT2854R (used in our 215 hp kits) and go up to 14 lbs of boost. After that you can go to our GT2860RS (modified by us to fit into the chassis) that will take you up to 18+ lbs. 8 lbs of boost is the limit on pump gas on a stock motor though.
This kit (180 hp) is designed to run on the stock fuel pump and with the stock muffler at 5 lbs of boost.
stopdropanroll
Thanks Allen, makes that decision allot easier and more like a possiblity sooner.
1steep800
- Oct 16, 2009
Thats sweet I just picked up my 09 mtx.I bought the sled for the reason of a turbo.Now $4000.00 gets me 180hp....awesome
WOW NICE WORK!!!!!!!!!!!!!!!!!!!
dirkdiggler
Suspended
Hey Allen Nice job on this Kit. You and your Father do a great job!!!!!
- Apr 17, 2003
- Menno, SD
- Menno, SD
dirk, see you at the Novi show?! We've got some sweet new parts coming for the 2010 Vector to crank some more hp out of those too!
legends14x
Allan, what kind of weight gain total are we talkin with this kit?? I this a bolt on tune and go or is this a tuner kit? Looking at this being next years mod (10-11). do you have some clutching to go with it???
- Apr 17, 2003
- Menno, SD
- Menno, SD
With the stock muffler it will gain about 6 or 7 lbs to the sled, but the weight is all centralized on the chassis. This setup is aimed at the bolt on and go riders. There is a clutch package to go with it listed in the "available options" up above.
