- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
FX Nytro, FX Nytro RTX, FX Nytro RTX SE Models
Stage 1: $385
Increases of 2-3 sled lengths down low and through the midrange with 3-4 mph gain on top end. Engagement RPM is 3600.
-Primary Spring
-Super Tip Weights
-Secondary Spring
-Billet Helix
Stage 2: $550
Increases of 2-3 sled lengths down low and through the midrange with 6-7 mph gain on top end. Engagement RPM is 3600.
-Primary Spring
-Super Tip Weights
-Secondary Spring
-Billet Helix
-Top Gear
-Chain
-Windage Plate Kit
FX Nytro XTX Model
Stage 1: $375
-Primary Spring
-Super Tip Weights
-Billet Helix
Stage 1: $385
-Primary Spring
-Super Tip Weights
-Secondary Spring
-Billet Helix
Stage 2: $550
-Primary Spring
-Super Tip Weights
-Secondary Spring
-Billet Helix
-Top Gear
-Chain
-Windage Plate Kit
FX Nytro XTX Model
Stage 1: $375
-Primary Spring
-Super Tip Weights
-Billet Helix
How would the stage 1 kit work with a 1,72" track?
- Apr 17, 2003
- Menno, SD
- Menno, SD
For a 1.75" track we use a different helix and secondary spring. The added traction of the taller track will show significant increases in the low to midrange acceleration as well as a much better backshift than stock.
JcHawk
Allen
Do you have any clutch kits ready for the XTX?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Just uncrated the XTX last night. I believe we will have just the Stage 1 kit for the XTX.
justinator
Srxspec said:Just uncrated the XTX last night. I believe we will have just the Stage 1 kit for the XTX.
Allen did you take a peek to see what the xtx has for gearing??
- Apr 17, 2003
- Menno, SD
- Menno, SD
XTX has the same gearing as the regular FX Nytro models. 21/39
Bpatch50
Srxspec said:Stage 1: $385
-Primary Spring
-Super Tip Weights
-Secondary Spring
-Billet Helix
Stage 2: $550
-Primary Spring
-Super Tip Weights
-Secondary Spring
-Billet Helix
-Top Gear
-Chain
-Windage Plate Kit
I will have Stage 1 kits in stock January 3, 2008 and hopefully Stage 2 kits January 10, 2008.
what exactly is the windage plate kit?
Why just the Stage 1 kit for XTX??
- Apr 17, 2003
- Menno, SD
- Menno, SD
Bpatch50 said:Srxspec said:Stage 1: $385
-Primary Spring
-Super Tip Weights
-Secondary Spring
-Billet Helix
Stage 2: $550
-Primary Spring
-Super Tip Weights
-Secondary Spring
-Billet Helix
-Top Gear
-Chain
-Windage Plate Kit
The windage plate kit is two plates that cover up the exposed fins on the secondary. This usually picks up 1-2 mph on top end.
landscape88
Has anyone had any experience with the Stage Two clutch kit and its claims?Srxspec said:Bpatch50 said:Srxspec said:Stage 1: $385
-Primary Spring
-Super Tip Weights
-Secondary Spring
-Billet Helix
Stage 2: $550
-Primary Spring
-Super Tip Weights
-Secondary Spring
-Billet Helix
-Top Gear
-Chain
-Windage Plate Kit
mad4snow
you can trust Allen if he says 2-3 sleds lengths and 6-7 mph on top you will get atleast that much and probly a little more more times than not
kmwharley
anything for a MTX running below 2500 ft?
- Apr 17, 2003
- Menno, SD
- Menno, SD
We have setup our own MTX at 1300 foot elevation using the same basic components as our Stage 1 clutch kits. We can set you up with a MTX clutch kit if you would like.
Daranello
Suspended
Can you add the windage plates to the XTX stage 1 kit??? If yes how much?
