- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Will be doing quite a bit of stuff here.
-Ulmer Racing Turbo Kit 8 lbs of boost 210 hp pump gas
-Better Boards
-Powder Claw track
-Already upgraded front shock springs
-Upgrading rear torsion springs
-Cutting up the back of the running boards to eliminate drag in deep snow
-Installing boost & O2 gauge
-Installing Trail Tank
As it came into the shop.....
-Better Boards
-Powder Claw track
Daranello
Suspended
Nice sled looking foward to seeing it come together, but what wrong with the stock front piggybacks shocks???
(unless you took them off cause there was no stickers)
Daranello
Suspended
also what kind of top end will you expect to get out of it with the ulmer turbo???
- Apr 17, 2003
- Menno, SD
- Menno, SD
Daranello said:Nice sled looking foward to seeing it come together, but what wrong with the stock front piggybacks shocks???
The MTX does not come with piggyback shocks. They come with a standard KYB shock with 1.7 kg springs. I kept the standard shocks but 2.5 kg springs on to help stiffen it up and keeping it from diving.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Daranello said:also what kind of top end will you expect to get out of it with the ulmer turbo???
This sled will not be about top end. It is a mountain sled and will stay setup that way with 20/40 gearing with the 3.0 pitch 2.25" lug track.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Starting the tear down....
Mounting Gauges....
Tearing down some more!
Mounting Gauges....
- Apr 17, 2003
- Menno, SD
- Menno, SD
Wildchild steering post relocation installed and ready to cut off the running boards and rearc the rears and install the Better Boards up front!
- Apr 17, 2003
- Menno, SD
- Menno, SD
Getting a few turbo kit parts laid out.
Charge tube under the tunnel and from under the tunnel to the intercooler!
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Keep the pics coming, looking forward to have a closer look at your turbo kit as the project moves forward.
obr
Looks good. You don't lower the compression, right?
- Apr 17, 2003
- Menno, SD
- Menno, SD
We do not change the compression on our Stage 1 kit. We will be testing a larger turbo with lowered compression for the FX Nytro when we get snow on the ground for Stage 2!
obr
sounds good to me...without lowering compression, these turbo installs would be an ease... I'd be interested to see how one of these kits performed agains the others with lowered compression and higher boost levels...Would be faster of the line and through the trees I guess....
Thanks, Bull
Thanks, Bull
- Apr 17, 2003
- Menno, SD
- Menno, SD
The installation of the turbo kit is very simple. You have to drill one hole out bigger and drill one new hole to mount the turbo. Then you drill the hole for the charge tube to come through the front. Otherwise no other modifications are needed.
A few more pics of cutting the running boards pretty much completely off and then reattaching the Better Boards and also cutting, heating, and bending the outside running board grip to match the new running boards!
- Apr 17, 2003
- Menno, SD
- Menno, SD
A little more progress made! Has been slow going as I haven't been able to put the phone down much lately!
Running boards all finished up!
New Powder Claw track & heavy duty torsion springs!
Charge tube and turbo mounting bracket set into the tunnel but not fully mounted!
Needing to enlarge one hole and measure and drill hole for other turbo mount bracket to bolt up!
- Apr 17, 2003
- Menno, SD
- Menno, SD
A few more pictures of turbo parts be installed. Still waiting on intercooler and then the sled will get buttoned up!
Modification of one rivet in the heat shield and also drilling one hole out to accept a bolt and one hole for other side of turbo mounting plate.
Dynojet Power Commander & Ignition Module installed
After tig welding some aluminum pieces back on the tunnel so it doesn't hurt your hands when you grab it back there when you're stuck!
