Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Lotsa setting for the Nytros and hopefully we can all help each other out. I'm asking for all the FX Nytro owners (base, RTX, RTX SE, XTX, etc.) here to write down what settings for each of the suspension components they are trying out, their riding style and weight.
Thanks to Crewchief47 for setting up an XLS program for all the settings. There's even a little comment box for any info you can share. Download the file, add your info, save it, post it and I'll try to update it regularly in the first post.
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
This is a good idea. I'll trust Grimm to keep it alive during the season.
I can still tweak the spreadsheet some if anyone has any ideas before it gets too big.....
You should be able to view this with IE7 if you don't have Excel. You can post your settings in the thread, PM me or Email(put 'Nytro suspension settings' in the subject please) me as well, just please follow the order in the current version of the spreadsheet. I will continue to update the file in THIS post so it may not be the same one you viewed/downloaded last week.
Here's a link from last year for more reading.
2008 Nytro setup troubleshooting
BLUEBALLER
- Jan 29, 2005
Any way to include all 5 versions of nytros? Something like this would have been handy last year with all the tuning guys were doing.
Maybe each page could be for the SE, RTX, XTX, STD, & MTX
Just a thought.
Just a thought.
Crewchief47
- Jan 16, 2006
Changes have been made to the excel file. Any other ideas are welcome, as long as it doesn't get too big. I'll add model specific sheets as it starts to fill up.
lucky_7
Added to origional.
Crewchief47
- Jan 16, 2006
I'm going to delete your uploads as I add them to the origional, ok guys!
- Apr 14, 2003
- Hessel, Michigan
I will send you mine to update
Daranello
Suspended
Lets do and XTX on Please!!!
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
You can add your XTX to the spreadsheet.
I was kind of hoping more people would add their 2 cents.
Crewchief47
- Jan 16, 2006
NOS-PRO said:I will send you mine to update
Your info added!
You guys can also PM me the info in the same order as the spreadsheet if you don't have excel. Can someone verify that they can view the file with IE7 (don't know if you can with firefox) by clicking on it and selecting 'open'? You can't have excel installed to test this for me.
IE7 works for me
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Anyone else have settings to share?
BLUEBALLER
- Jan 29, 2005
I did - but I've since revalved. So, I have to start the painful task of dialing it in again. I'll update when I'm done - if it takes as long as it did last year, then it should be around Feb. 09.
LJ 452
I basically set everything to the middle, all valving and left the limiter straps where they were. My plan was to start adjusting on the first ride, or if mother nature cooperates in the back 40. We'll definently keep this going and update any thoughts, reactions.
sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
Re: FX Nytro Member *Suspension Settings*
Edit Crewchief47: Added to spread sheet.
- 6K
- 16K
