Gauge Pods
northof50
Northern ,mb
Canada
14 viper LTX Deluxe
Hello,
I was looking for a gauge pod that would blend in with the factory dash board.
Is there any on the market, or do I have to do this myself?
I am looking to mount an AFR gauge & boost Gauge.
Thanks for your help.
not sure if there is any out there that will look "factory" but this is what i did to keep the factor look and keep it clean. its a 8 dollar bicycle handlebar bag
that fits the gauges and holds all of the extra wires perfectly. the gauges and gauge bracket are from hurricane performance.
th
thView attachment 97759View attachment 97760
Very cool!
Speaking of gauges. I worry someone will steal my stocker. I can remove it in two seconds.
Nice work!
Thank you. For the input.
I now have a plan!
Like the stealth mount. Was told that Pat's in Greenland MI had a push turbo sled this winter and that they had mounted the gauges into the black plastic flares that are on each side of the steering column. Basically on each side of the handle bar bag. I did not see it first hand and would love to see a pic if anyone has one. The flares are about three inches wide just before the stock gauges and there is nothing for four inches under them. Was thinking the two inch gauges from AEM would fit in there fairly well. Just another idea.
Now that is cool, sleeper cool!!!!
Does anyone know if you can mount the gauges in the dash to the left or right of the steering post? Cat has their intake vents pulling from that spot so if yamaha has not filled it with something it should be ok.
Yes they do have them there but they are unreadable when driving the sled.
My custom made mount, this is the first go around. The second one has the gauges closer together and set back under the windshield further.
What I meant was they are facing upwards in those holes and tucked under the handlebars. You cannot read them when driving fast or at WOT like a gauge that is mounted just below the windshield lip above teh dash pod.
