GPS Map with Waypoints in the Shawinigan Area
Will this work used with lowrancne mapcreate software? The files are stored as "usr". Thanks J
QCrider,Do you know which version of mapsource this was created in my version is 4.09 and will not open the file (It says it was created in a different version and I'll be contacting garmin for a converion update but will probably ned the version # that you are using
The one I've been playing with is the snowmobile map from GPSQuebec.com.
Most of the trails, pouvouries and so on seem to be there if you display the necessary level of detail and zoom in.
Should make a welcome addition to the rides this year: it does autorouting from point to point using the sled trails, very nice if you're looking for the short way home...
