actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Yeah my phone charging case is currently mounted just as twyztid did. Ram diamond base plate screwed to dash, short arm, diamond plate adapter to 3D printed adapter to Arkon case. Ram mount possibilities are almost unlimited. I am replacing that with the OSP plate. I wasted some time this morning and modeled it up roughly.
ateick
- Mar 11, 2019
- '24 Rene XRS 900R
'18 SR Viper RTX (SOLD)
'20 Poo XCR 850 (SOLD)
I used a RAM mount as well. Puts it in a great position above the gauges. Wired my battery tender to the goggle bag and have a dual USB connection there that allows my to plug in the GPS plus one other thing like a phone charger. Then I plug my tender in there when stored.
Joe blk viper
- Jan 14, 2019
- Indiana
- 2018 SR Viper
Thanks everyone. I talked to Ram and the have a handlebar mount and GPS specific holder they led me to. One of my customers said he has been using something similar and has been running for three years on his nytros doo 850 and assault 800 and has had good success.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Looks like something Travis at BOP could make up now that OSP is out of business..... I sure would order one!Yeah my phone charging case is currently mounted just as twyztid did. Ram diamond base plate screwed to dash, short arm, diamond plate adapter to 3D printed adapter to Arkon case. Ram mount possibilities are almost unlimited. I am replacing that with the OSP plate. I wasted some time this morning and modeled it up roughly.
yamarider13
- Mar 9, 2014
- East Central Wi
- 2014 Vector LTX
2015 Venture GT
www.trailsystems.com has mounts. I have one for my Vector and works well. I have it installed right above my gauges. Looks like they have it for Viper and Winder also.
yamarider13
- Mar 9, 2014
- East Central Wi
- 2014 Vector LTX
2015 Venture GT
By the way I also have a 5" Nuvi with vvmapping.
rbell14
I have one of their GPS mounts on my wife's sled. They have nice setups for GPS.
actionjack
- Apr 9, 2005
I finally got around to moving my GPS from the riser to the OSP bracket over the gauge.
This shows how I mounted my Arkon case where my iphone rode last year using Ram 1” ball components.
IMG_4681
IMG_4682
I routed the power for the Amps cradle through the bottom hole from the previous ram mount location.
IMG_4684
I wired up my Amps cradle, my RideLite and a Mic Tuning dual USB charger to the wiring for the accessory socket. All are when key is on (engine off or on).
IMG_4687
I always use a tether for my GPS so I drilled a hole in the top corner.
IMG_4683
I found the screws for the black cowling just barely long enough where the plate mounts. I may order new or source longer screws.
IMG_4686
Back together all powers up correctly.
IMG_4688
Wannaviper
- Mar 18, 2014
- West Gardiner, Maine
Are the OSP brackets still available anywhere?
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
I've been looking for them for a few weeks now and not had any luck. Seems OSP is out of business; website down, posted phone numbers no longer in service. I'm hoping Travis of BOP would pick up on the need and produce a similar product. I'm first in line for one Travis!Are the OSP brackets still available anywhere?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I actually have a used osp mount. I will work on this. Any new features or changes i should incorporate?
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
Since I've not owned one yet, I'd be happy to get one at all. I believe the OSP product had a large OSP logo cut through it; I was never a fan of that, I preferred their "blank" one that they started to offer more recently. Unfinished aluminum would be fine for me (ala the BOP fuse relocate plate - love that!), but the black painted or powder coated was a nice touch. Definitely needs a BOP sticker on it! ;-) although a windshield bag will likely cover most of it anyway.
actionjack
- Apr 9, 2005
I'd suggest longer screw for where the mount point is. And a common bore pattern say for ram mounts and Amps cradle.I actually have a used osp mount. I will work on this. Any new features or changes i should incorporate?
Joshua
- Apr 14, 2010
- Newfoundland
- 2018 Yamaha Sidewinder BTX LE 50TH
IMG_4681
IMG_4682
IMG_4684
IMG_4687
IMG_4683
IMG_4686
IMG_4688
The cable that is connected to the cradle, can you unplug it? Wondering if my cable can just plug into it.
actionjack
- Apr 9, 2005
The amps cradle cable is hardwired in the mount and under the dash all of my connections are soldered and heat shrink protected. You could create a plug set up and you can route the cable under the corner of the gauge without having to add a hole to route the wire.The cable that is connected to the cradle, can you unplug it? Wondering if my cable can just plug into it.
